Parking / Emergency brake cable adjustment HL 2009 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 03:20 PM   #1 (permalink)
View ddrhigh09's Photo Gallery
2nd Generation Parking / Emergency brake cable adjustment HL 2009
On my 2009 Highlander Limited, I have found that there is a small opening in the cover/ dash cowling right above the foot pad on the P/E brake pedal. A 10mm deep socket on an extension fits over the adjustment nut on the end of the cable. There is no need to take off the side panel cover to take up slack in the cable.
The opening is about a half inch in size. looking straight up, you should see the threaded end of the cable and the silver adjustment nut. I turned it clockwise to tighten the cable.
ddrhigh09 is offline   Reply With Quote
The Following User Says Thank You to ddrhigh09 For This Useful Post:
TrailDust (09-22-2011)
Old 09-22-2011, 03:30 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $613331
View Zembonez's Photo Gallery
If you have to adjust your E brake much, you need to check out your brake pads / shoes. Sounds like they are worn out.
Zembonez is offline   Reply With Quote
The Following User Says Thank You to Zembonez For This Useful Post:
ddrhigh09 (09-22-2011)
Old 09-22-2011, 03:53 PM   #3 (permalink)
I will have to replace the rear disk pads soon and I'll take a look at parking pads then. Or, are they the same? I haven't been in there yet.
Normally, I don't use the parking break. I do use it when launching and retrieving my 4,800 Lb boat/trailer. The brake needed to be pushed pretty hard to keep the vehicle from rolling back toward the water. After a while, the brake wouldn't hold it. I figured the cable stretched as they do under a lot of strain. I haven't looked into adjusting the pads yet.
I'll see in a month or so and report back.
Thanks for the post.
Dave
Old 09-22-2011, 03:56 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
It is cool that they provided such an easy way to adjust the cable though... Most are much more difficult.
