high beam light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 08:48 PM   #1 (permalink)
View highlander123's Photo Gallery
high beam light
I discovered when I turn the high beam light on, the low beam light seem off. My father 2006 corolla the low beam still on when the high beam turn on. Does the drl used high beam light?
2010 highlander base 4wd
highlander123 is offline   Reply With Quote
Old 09-22-2011, 10:20 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000164
View humanoid's Photo Gallery
Yes, the DRL uses the highbeam at 50% I believe.
This is my sig.
humanoid is offline   Reply With Quote
Old 09-23-2011, 08:13 AM   #3 (permalink)
View guytdt's Photo Gallery
I believe it's the law in many states that you can only have one set of driving light on. So when high is on, low will be off.
guytdt is offline   Reply With Quote
Old 09-23-2011, 08:30 AM   #4 (permalink)
View Sky1111's Photo Gallery
What is even worse, the fog lights will turn off once you high beam... you end up having a lot less light on the road.
2008 Highlander Limited AWD Blizzard Pearl, Navi, removed charcoal filter, Philips X-tremeVision H4s, OSRAM HighBreaker Plus fogs, AVS bugshield and window visors, FIAMM dual horns, SteelCraft Bull Bar, LED reverse/all interior/side mirrors, stainless steel exhaust tip
Sky1111 is offline   Reply With Quote
Old 09-24-2011, 08:42 AM   #5 (permalink)
It is good for people who alway drive with hi/low beam on. I hate the the people drive whit hi beam on.
Old 09-25-2011, 11:35 AM   #6 (permalink)
View dallen3737's Photo Gallery
You would not use your high beams when it is foggy and it is the law that the fog lights must turn off when the high beams come on. You would also have to consider the load on the alternator if you were able to burn all the lights at 100% at the same time
dallen3737 is offline   Reply With Quote
Old 09-25-2011, 12:06 PM   #7 (permalink)
View MikeyD25's Photo Gallery
Originally Posted by dallen3737 View Post
You would not use your high beams when it is foggy....
I'd prefer that the low beams weren't on when the FOG LIGHTS are, but if they have to be on then let them come on when the parking lights are on as well. Give the driver the option of parking lights + fogs or low beams + fogs. Definitely NO DRLs + fogs!
MD
In memoriam NYPD DAOS / NYS OIG #77
'12 Highlander SE - Sizzling Crimson Mica / Black Interior / V6 / 4WD + Tow Prep Pkg; OEM Mud Guards; OEM All-Weather Mats; Camry horns; Weathertech Vent Visors & AVS Bugflector II.
'09 RAV4 Base
- gone.
'06 Highlander Base
- gone.
R.I.P Seattle Mike / Joe S.
MikeyD25 is offline   Reply With Quote
Old 09-25-2011, 01:36 PM   #8 (permalink)
I install two set of foglight on my last car Hond accord, never have a problem. I prefer turn the low beam and high beam on when I driving in a dark raining day with no car on road, but this highlander not allow me do it.
