wiring through firewall - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2011, 09:24 AM   #1 (permalink)
View highlander123's Photo Gallery
I want make the foglight, but don't know how to wiring through firewall, help....
highlander123 is offline   Reply With Quote
Old 09-24-2011, 10:28 AM   #2 (permalink)
Gameroom cash: $363535
View newsrv's Photo Gallery
See posts 6 & 7
Fog light Diameter
2008 Highlander AWD, Blizzard Pearl & Ash interior, loaded but no rear entertainment
newsrv is offline   Reply With Quote
Old 09-24-2011, 01:34 PM   #3 (permalink)
[QUOTE=newsrv;3669657]See posts 6 & 7
Fog light Diameter[/QUOTE
Thank you, but I still need bigger picture to see which position to through firewall.
Old 09-24-2011, 03:12 PM   #4 (permalink)
It is not the firewall. The opening is to the left wheel well. Just follow the hood release cable and you'll see where it goes into the wheel well. Take a look at this posting, second picture. It shows the hood cable release from the wheel well perspective.
Wiring for 7 Wire Trailer Setup
Old 09-24-2011, 09:24 PM   #5 (permalink)
thank you, I will find it out tomorrow.
Old 09-25-2011, 06:40 AM   #6 (permalink)
luck123's Avatar
View luck123's Photo Gallery
It's been a while now, but when I ran a power cable for my subwoofer, I believe I entered via firewall in the passenger compartment footwell. There is a run of wires going through a grommet in the firewall....I just shoved the wire through. Took a bit of patience, but if I recall, wasn't that hard. You just have to remove the panel under the dash by removing a few retainer clips to be able to access it. Note that this will require more wire since you have to go to passenger side, then back since the battery is on the driver side.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 09-25-2011, 11:11 AM   #7 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
In the passenger foot-well (after removing the black AC cover that hides everything down there) there is a rubber grommet that runs through the firewall. There is a 3/4" band of wires going through it. Below the bundle (about 1cm, still part of the same rubber grommet) there is a plug looking thing. It is actually another hole to run wires. If you cut this plug off using a razor blade or scissors there will be a hole into the engine bay you can run power lines through. I ran my 2 8-guage power lines for the amps through this hole.
It goes straight into the engine bay. Its easiest if you stick a cloths hanger through (working from inside the car INTO the engine bay, taping the wires to 1 end) and pushing it till you see it in the engine bay, as the grommet can be difficult to get your arm to inside the engine bay.
This is what Luck123 is talking about as I used his thread to find this hole through the firewall
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 09-25-2011, 02:02 PM   #8 (permalink)
Thank you sweeneyp and luck123, this very useful information, but the engine bay is very deep and overcrowded, it is difficult to me. I finally decided to install a remote foglight. I remember the remote foglight sold in walmart, so I don't have to wiring through firewall. any advice please.
Last edited by TrailDust; 09-25-2011 at 02:28 PM. Reason: Image removed from quote.
Old 09-25-2011, 02:27 PM   #9 (permalink)
sweeneyp's Avatar
So your talking about a wireless/remote relay kit. I didn't know walmart sold wireless kits, I've never seen them. Are you asking for wiring advice, I'm kinda confused now? Do you have a link to the kit you found?
Old 09-25-2011, 03:04 PM   #10 (permalink)
sorry It is wireless fog light. My friend and me bought it in walmart and install to his car about seven year ago. for now I don't know walmart still sold it or not. I will check it out.
