120 volt inverter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2011, 10:41 AM   #1 (permalink)
View john480's Photo Gallery
USA 120 volt inverter
i been looking for some info on the 120 volt outlet in rear storage .im not having any luck,what im looking for what the wattage is and is it worth the upgrade ?thanks
john480 is offline   Reply With Quote
Old 09-25-2011, 11:08 AM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415785
View sweeneyp's Photo Gallery
I'm not positive at the moment as I'd have to go out to my car to confirm (I'm pretty sure it has it printed on the outlet cover as I've looked at it before, but can't go to my car at the moment), but I believe its somewhere in the ballpark of 100 watts. The actual inverter is pretty small (i.e. low power) and under the shifter in the center console, so its a paint go get to and replace. I have never used it, I just use one I have laying around that plugs into a 12v outlet. A 12v outlet can provide around 180 watts with the 15 amp fuse. So I would suggest to save money and just use one of those. If you need more than the 180 watts, you can just run a wire-harness to the battery and install like a 400 watt one inside the car.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
