Please help! Noise after fluid change - is it bad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2011, 07:13 AM   #1 (permalink)
View kbornkessel's Photo Gallery
Hello -
I did a search and couldnt find anything. I have a 2009 4cyl with 6 speed. 70,000 miles. I added a transmission cooler last night and also dropped the pan and changed the filter. Everything went fine. I filled the cooler and then added the same amount of new fluid back in. Put in about an extra 1/8 quart of fluid to compensate for hoses. Car runs perfect but after the fluid heats up, when you put it in reverse it makes a weird fast clicking sound the entire time it is in reverse. Has nothing to do with car moving. Put it in reverse it starts, take it out it stops. Has to be the pump. Too much fluid? Too little fluid? I tried jumping the DLC to see the tranny temp but it would not work on my vehicle. Any advice? Thanks so much in advance.
kbornkessel is offline   Reply With Quote
Old 10-02-2011, 11:32 AM   #2 (permalink)
summerwind's Avatar
Gameroom cash: $450530
View summerwind's Photo Gallery
Sorry looks like no Tranny mechanics here....
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 10-02-2011, 01:39 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
I agree with summerwind. You may get lucky and have a fellow Highlander owner respond with some insight, but odds are slim because there's not as many mechanical types among the owners. Tell you what, post up a new thread to the 2nd Gen Tacoma forum and ask there as it's a very similar vehicle and many have performed the transmission cooler mod. Go for it, I won't consider the other thread a double post.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 10-02-2011, 03:37 PM   #4 (permalink)
AvConsult
Gameroom cash: $193905
View AVConsult's Photo Gallery
mmm, I doubt it's the pump--the ones near death I've heard whine when cavitating or make a sand in the bearing noise in all gears. It is possible you have air trapped somewhere related to your fluid, or you have a hose/line vibrating on something it shouldn't (i.e hoses relax when hot). If it goes from neutral to reverse in under 2 seconds and isn't slipping, forward gears shift fine and no dash lights, then I doubt anything serious is wrong.
'08 Highlander Base with goodies
'02 Highlander V6
'01 Honda Civic
'93 Camry LE V6 (departed)
AVConsult is offline   Reply With Quote
Old 10-03-2011, 12:00 PM   #5 (permalink)
View valkyrie's Photo Gallery
I would agree with AV Look hard it the lines you put on and your cooler install for anything making contact only when in reverse and engine is slightly torqued.
I did a search in all of my databases and did not come up with any common noises or pattern fails with this tranz. Good luck
valkyrie is offline   Reply With Quote
