Originally Posted by ajlee777
thanks
Yes the switch is on drl/off. Also my dealer checked the customization settings and the"daytime running light system" is set to yes. My dealer told me to bring it back and they will have to work with headquarters to determine the problem.
Now I'm confused. Your first post states the DRL won't come on. But in this last post, you note that you've manually turned the DRLs off.
If you have it set to DRL off, then all lights (including the DRL) should stay off at all times. If you set the switch to Auto on the stalk, then the DRL will be on at all times unless it gets dark enough and it switches over to headlights automatically. In the Auto setting, you will basically have lights on at all times (either DRL or headlights).
