Originally Posted by mtran868
I have a 2008 base model Highlander with no tow pkg. I want to tow a 2500 lb TT with it. Does anyone know if it's better to use the "standard" shift option? Or is it better to stick with the auto shift?
If i'm doing 60 on the hwy, can I switch from auto to standard?
Is that 2500lbs dry or loaded? What is the towing capacity of your HL? Keep in mind that that number includes cargo and passengers over and above a 150lb driver.
In any case, you will likely need to use the shifter to manually shift gears. Yes you can go from Drive to Manual Mode while at highway speed, but it will drop to 4th gear from 5th, so I wouldn't do it unless you are slowing down while starting up an incline, and the automatic tranny downshifted (or is about to downshift) to 4th already. What I do is keep in in Drive if I am on a flat road and the tranny is not constantly downshifting. Otherwise, I use the manual shifter and don't go higher than 4th. Always keep an eye/ear out for constant downshifting and upshifting from the automatic tranny, and avoid that since that will kill your transmission.
Also, keep in mind that if you have it manually shifted to 4th, it will downshift. It will just not go higher than the gear you selected (i.e. if you select 4th, 5th will never be reached, but 1st, 2nd, and 3rd will be reached as per normal.
Hope this helps.
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
