A/C Button - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2011, 08:03 PM   #1 (permalink)
View highlander123's Photo Gallery
A/C Button
It was cold in the morning, I set the temperature middle and turn the fan on, the ac botton light automatic turn on, I remember last turn the engine off the ac botton ligh was off. Is it normal?
highlander123 is offline   Reply With Quote
Old 10-07-2011, 08:24 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3632850
Keep an eye on this issue and see if it keeps happening over the next few weeks. If the issue continues what it may be is the compressor clutch relay for the air conditioner. I had this exact same problem earlier this year and that was the cause. Besides being irritating, the main reason you'll want to get this fixed is when the faulty relay causes the A/C to turn on by itself it's actually been engaging/disengaging the A/C compressor during the entire time your engine has been shut off, which causes a huge drain on your battery. This issue ruined a battery for me...took three years of life right off of it.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 10-07-2011, 09:59 PM   #3 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $535595
View 05Moose's Photo Gallery
If you had it set to defrost or floor/defrost, it does turn on the AC automatically. (just a reminder since you didn't specify which setting you had it on when you turned the fan on)
Originally Posted by Chalkie View Post
That's why he be a moderator and we be the peons... cleverness!
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline   Reply With Quote
Old 10-07-2011, 11:23 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Excellent point.
2002 Avalon XL
Old 10-08-2011, 06:36 AM   #5 (permalink)
The ac light still off when I set to defrost or floor/defrost and turned the fan on...
Old 10-08-2011, 10:16 AM   #6 (permalink)
Got Snow?
05Moose's Avatar
Yeah, I couldn't remember whether it lights up when the compressor comes on or not when it's on defrost (it does on the Taco). I've had the Taco for almost 7 years, so I have more things memorized on it than I do on the HL. And it's like the wiper delay switch, Toyota can't seem to decide which way they're gonna go with it.
Old 10-08-2011, 02:06 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
The A/C does not light up when in the defrost mode as it's "running in the background" to dehumidify the air. I've always felt that's stupid of Toyota to not indicate ANY TIME the A/C is operating. At least that's how I feel about it.
2002 Avalon XL
Old 10-08-2011, 09:15 PM   #8 (permalink)
So when I set it face or floor mode from defrost mode, does the A/C still turn on?
Old 10-09-2011, 01:14 AM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Once you select any mode other than the two defrost settings the A/C automatically turns off.
2002 Avalon XL
Old 10-09-2011, 07:12 AM   #10 (permalink)
Great! Just hate A/C bottle don't light up on defrost mode. Can I set defrost mode with A/C off? I remember my honda can.
Old 10-09-2011, 09:16 AM   #11 (permalink)
summerwind's Avatar
Gameroom cash: $450530
View summerwind's Photo Gallery
What system are we talking about
Manual HVAC or Automatic?
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 10-09-2011, 01:43 PM   #12 (permalink)
Do you feel lucky?
TrailDust's Avatar
I assumed the OP is talking about the HVAC system.
2002 Avalon XL
Old 10-09-2011, 03:31 PM   #13 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
Canada
It is probably a good thing to leave the AC as designed (to come on with the defrost functions). The load on the AC is minimal in this capacity but more importantly it keeps the "O" rings and seals lubricated in the compressor. Keeping the AC off for an extended time could cause leaks.
Ralph6410 is online now   Reply With Quote
Old 10-10-2011, 09:42 AM   #14 (permalink)
Got Snow?
05Moose's Avatar
Not without doing some electrical mods. People have done it on the Tacoma...
But this is why you really shouldn't do the mod to separate defrost from the AC. Although, there are times when I'd rather leave the compressor off because once you use it, you have to continue to use it lest it cause the fogging situation. IIRC, the recommendation has always been to run the compressor at least once a month to keep the seals lubricated. Can't remember how long it was supposed to be run though (10 minutes)?
Old 10-10-2011, 12:26 PM   #15 (permalink)
summerwind's Avatar
If so the OP should read the following on how the "Neural Network" controls the HVAC.. ITS ALIVE!!!
AC Neural Network
