Suspension question regarding 2010 Highlander Base model - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2011, 04:14 PM   #1 (permalink)
View mslerner's Photo Gallery
Does anyone know if there is a difference between the suspension on a Highlander Sport and the Highlander Base??? There IS a difference in Part#'s but the Toyota parts guy didn't know if the sway bars were thicker or if the shocks/springs were stiffer. I never drove the Sport model, but my 2010 Highlander Base model understeers too much and I would like to correct it (maybe install the Highlander Sport rear sway bar if its a thicker diameter, etc.)
Here are the part#'s for the Base model and the Sport model:
2010 Toyota Highlander – Suspension – Springs, Struts, Sway Bar Part#’s
BASE
>> 48510-80480 ABSORBER
>> 48520-80220 ABSORBER
>> 48131-48610 SPRING, C
>> 48811-0E030 BAR, STAB
>> 48530-80428 ABSORBER
>> 48540-80004 ABSORBER
>> 48231-48480 SPRING, C
>> 48812-48170 BAR, STAB
>> SE
>> 48510-A9840 ABSORBER
>> 48520-A9530 ABSORBER
>> 48131-0E090 SPRING, C
>> 48530-A9720 ABSORBER
>> 48540-A9370 ABSORBER
>> 48231-0E070 SPRING, C
mslerner is offline   Reply With Quote
Old 10-12-2011, 05:40 PM   #2 (permalink)
Banned
View MAToyotaSales's Photo Gallery
It gets a little confusing here...
The SPORT model, yes it's a SPORT suspension.
An SE Highlander is *not* a SPORT model. The sport was discontinued halfway through 2010, replaced by the SE which does not have a sport suspension.
MAToyotaSales is offline   Reply With Quote
Old 10-12-2011, 09:08 PM   #3 (permalink)
View shellback's Photo Gallery
What are the differences in the sport suspension? Are springs and shocks stiffer? If so how significant is the difference?
shellback is offline   Reply With Quote
Old 10-13-2011, 08:22 AM   #4 (permalink)
Banned
It's a slightly stiffer ride, not by much but you can feel it. Similar to driving a Camry SE vs. an LE.
Old 10-18-2011, 07:26 AM   #5 (permalink)
I would assume the "slightly stiffer ride" of the Sport vs. Base is a result of the lower profile tires. I just picked up the part#'s for the Sport model. If anyone out there has a Sport model, would you mind measuring the rear sway bar with vernier calipers, etc. and get back to me???? Thanks, Mike
P.S. Here are the Sport suspension part#'s
FRONT
48510-A9850 ABSORBER
48520-A9540 ABSORBER
REAR
48530-A9730 ABSORBER
48540-A9380 ABSORBER
FRONT
48131-0E100 SPRING, C
REAR
48231-0E080 SPRING, C
FRONT
REAR
