Video input to the multifunction display. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2011, 09:36 PM   #1 (permalink)
View chadwick101's Photo Gallery
I'm looking for a way to get video into the MFD. I have a 2009 limited with nav. My backup/reverse camera comes through the nav. I'm trying to have a switchable video input on the MFD for another video based menu. (MP3) I don't have the wires on the connector for the camera.
As I understand it, pin 2 puts it in video mode, and pin 12 and 4 are the camera.
My question is: what is the pin 2 trigger? +12v or GND. Are the MFDs the same between Nav and non Nav HLs? This website makes it look like the same part number. http://www.toyotapartszone.com/oem/t...910-48040.html
Thanks for any info,
Chad
chadwick101 is offline   Reply With Quote
Old 10-20-2011, 04:48 PM   #2 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
If.. you get something that works Chad let us know. I have been toying with adding a front facing camera that would come on at the push of a button. Better to monitor those close fit parking spots and high curbs.
Ralph6410 is online now   Reply With Quote
Old 11-04-2011, 07:44 PM   #3 (permalink)
Well, I got it working on the nav screen. I need to look at the pinouts on the back of the NAV, but basically I split the camera input from the back up camera with a relay, and send 12v to another pin to trick it into reverse mode. That 12v did require a diode to stop 12v going back into the rest of the car. When I first set it up without the diode, the reverse indicator on the instrument panel lit up, and I'm not really sure what else was effected so I added the diode. Also, since it thinks it's in reverse, you always get the "Check your surroundings" message on the bottom. Other than that, it seems to work pretty good. I never really figured out the MFD pinouts. I looked up how much it cost and decided not to go to deep.
Chad
The Following User Says Thank You to chadwick101 For This Useful Post:
Sky1111 (11-07-2011)
Old 11-04-2011, 09:29 PM   #4 (permalink)
Canada
Well done
Old 11-07-2011, 08:52 AM   #5 (permalink)
View Sky1111's Photo Gallery
Chad
Thanks Chad - do you think you can create a sticky with step by step guide with pictures? that would help the entire community a lot
I would like do the same mod, but I do not know how to get to back of the nav without ruining the car... what tools for example to be used?
2008 Highlander Limited AWD Blizzard Pearl, Navi, removed charcoal filter, Philips X-tremeVision H4s, OSRAM HighBreaker Plus fogs, AVS bugshield and window visors, FIAMM dual horns, SteelCraft Bull Bar, LED reverse/all interior/side mirrors, stainless steel exhaust tip
Sky1111 is offline   Reply With Quote
