2011 Highlander - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2011, 11:56 AM   #1 (permalink)
View jjdimsum's Photo Gallery
2011 Highlander
I trying to find the location of the Reset button for the TPMS. Does anyone know were it is. I look in the Glove compartment and under the steering wheel
jjdimsum is offline   Reply With Quote
Old 10-26-2011, 12:57 PM   #2 (permalink)
Gameroom cash: $204000
View DavidHB's Photo Gallery
its under the dash, near your right knee when you are in the drivers seat. you cant see it without looking up at the bottom of the dash. once you find it you will be able to push it without looking. but probably not the first time. just stick your head down where your feet go and look up.
DavidHB is offline   Reply With Quote
Old 10-26-2011, 02:46 PM   #3 (permalink)
View GregC6's Photo Gallery
once you get the right psi and move the car a couple feet the light will reset itself...
GregC6 is offline   Reply With Quote
Old 10-26-2011, 04:19 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
Common Problems & Solutions sticky thread.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-26-2011, 06:20 PM   #5 (permalink)
View dward's Photo Gallery
The timing on this thread is great. The light on our '11 came on a couple of days ago. I added pressure to all 4 tires (32psi). They were roughly around 26-27psi.
The wife drives the HL and indicated the light was still on after a couple of days. I tried the reset button but no luck.
The light blinks one time and then stays on.
Should I disconnect the battery for a few minutes ?
Thanks
Dennis
2005 Tacoma 4X4 - 4 door SR5
2011 Highlander SE - V6
dward is offline   Reply With Quote
Old 10-26-2011, 06:25 PM   #6 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
Your HL is monitoring 5 tires.. check your spare
Ralph6410 is offline   Reply With Quote
Old 10-26-2011, 06:46 PM   #7 (permalink)
TPMS reset
Thanks...I got it...improper technique
I turned the key on and waited for it to flash, then pressed the 'SET' button until it flashed 3 times. The light stayed on, then I backed out in the driveway and drove back in the garage and it went out...
Thanks again, I will check that spare to...
Dennis
