Auto on/off lights + turning off engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2011, 12:27 PM   #1 (permalink)
View crazyjeys's Photo Gallery
i have a 2010 base model with auto on/off lights. whenever i turn off the engine at night (or in covered areas) the lights remain on but does not turn off until i lock the car and press it twice. is there any mod that considers a timer for the lights to shut off for like 30 secs after turning off the engine?
crazyjeys is offline   Reply With Quote
Old 10-27-2011, 01:34 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
There should be a delay. Have you sat there for like a 1 min and see if it turns off on its own? Mine does from the factory, and you can turn them off with 2 locks just like yours.
You can modify the length/on-off of the delay at the dealer.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 10-27-2011, 04:01 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
See the Common Problems & Solutions sticky for a link to more info about the dealer mod that sweeney referred to.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-27-2011, 06:55 PM   #4 (permalink)
View spung1's Photo Gallery
At my last oil change, I had the dealer set it to zero. Now the lights turn off when I open the door. Much better
spung1 is offline   Reply With Quote
Old 10-27-2011, 09:42 PM   #5 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
Canada
That is the way mine is set as well..works for me.
Ralph6410 is offline   Reply With Quote
Old 10-28-2011, 09:33 AM   #6 (permalink)
i sat there for 10 minutes and it does not turn off. there's no way to set it DIY? i might just have to bring it to the dealer and ask them to set it to zero too.
Old 10-28-2011, 11:02 AM   #7 (permalink)
View jdw67's Photo Gallery
Wow, is it really 10 minutes? Or is time moving really slow since you're just watching your lights?
I think my lights stay on for about a minute or so...
Edit: Sorry, my reading comprehension is way off this morning. I thought it factory set at a minute???
jdw67 is offline   Reply With Quote
Old 10-28-2011, 11:35 AM   #8 (permalink)
i was unloading some grocery and took me like 10 minutes to do it and the light never turned off until i press the lock on the remote twice.
that's what i thought too, i guess i would have to bring it back to the dealer then.
Old 10-28-2011, 12:05 PM   #9 (permalink)
Wayward_Traveller's Avatar
Gameroom cash: $266929
View Wayward_Traveller's Photo Gallery
I know on mine they stay on for 30 seconds after I close the last door and lock the rig once.
But if I am in the hatchback unloading stuff it waits until 30 seconds after I close the rear first.
If yours is taking that long with the doors looked then yeah you need to take it back to the dealer and have the delay changed.
It almost sounds like your delay is disabled.
2008 Barcelona Camry SE V6 - Gone
2009 Magnetic Grey Metallic Venza AWD V-6- Gone
2011 Sizzling Crimson Highlander SE 4WD - Gone
2011 Blizzard Toyota Venza - 4cyl - AWD
2012 Hot Lava Release Series Scion XB
Wayward_Traveller is offline   Reply With Quote
Old 10-28-2011, 12:08 PM   #10 (permalink)
sweeneyp's Avatar
Its part of the computer settings in the car. there is no way to change it unless you go to the dealer. They have to use a special tool/computer that allows them to access the car ECU settings. That is strange yours came with no off feature preset. While your there I would look over the other posible modifications you can do while they got the computer set up (like DRL's, seatbelt chime etc...) to see if you want any of those changed.
Old 10-28-2011, 01:19 PM   #11 (permalink)
Silver Bullet Driver
junebug1701's Avatar
View junebug1701's Photo Gallery
All doors and the hatch must be shut before the timer starts. Once they are shut the default time is either 30 or 60 seconds. You don't have to lock the doors, just shut them. If you were unloading groceries, then I assume the doors were not shut.
junebug1701 is offline   Reply With Quote
Old 10-28-2011, 02:01 PM   #12 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Yes, the dealership uses their scan tool, called Techstream, to change the settings for the lights (and a hundred other things, too). If they try to charge you, don't let them, plenty of dealers (including the one I work at) will do it the first time for free.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 10-28-2011, 02:02 PM   #13 (permalink)
yes the doors are left open. i'll try to shut the door and see if it will trigger the delay. thanks for all the replies!
Old 10-28-2011, 02:04 PM   #14 (permalink)
Need For Speed
^That's probably your issue. If I leave one of my doors open the lights will stay on regardless of how much time goes by.
Old 10-28-2011, 03:53 PM   #15 (permalink)
Do you feel lucky?
TrailDust's Avatar
+1 My dealership never charges for this sort of thing, they emphasize customer service. Heck, they didn't even charge me when I knocked the rocker panel off in the desert. Labor, new clips, no charge.
2002 Avalon XL
