headlight help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2011, 10:41 AM   #1 (permalink)
View highlander123's Photo Gallery
headlight help
Just bought a headlight bulb (H4), Want to change today, first unplug the connector, send want remove the ruvver cover, but whatever how hard I pull the rubber cover just can not get it off, it seem permanent seal. someone know how to remove it?
highlander123 is offline   Reply With Quote
Old 11-05-2011, 01:18 PM   #2 (permalink)
View PhotonDreams's Photo Gallery
I changed my bulbs about three years ago when I first got the car. My memory is that those rubber caps were hard to pull off. I just went out to check and I'd say you just have to pull hard on the tabs to get them off. One trick you might try is slip a flat blade screwdriver in the edge at the top, pry, and see if it helps get it started as you pull on the tab. When you get them off I'd put some silicone on the edge before putting them back on. Good luck.
PhotonDreams is offline   Reply With Quote
Old 11-05-2011, 05:33 PM   #3 (permalink)
If I pull too hard I worry to tear the rubber cap, or wait for summer when the weather is hot so can pull it off easy?
Old 11-05-2011, 05:45 PM   #4 (permalink)
No need to wait for summer. Just get a hair dryer and blow warm air into the area till all the parts are as warm as a summer day.
Old 11-06-2011, 01:59 AM   #5 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
Mine came of fairly easy using the two tabs (I have to take mine off a lot to modify my projectors). Just pull on one of the two tabs and try to do what PhotonDreams said. Don't worry about tearing the rubber boot, its pretty strong.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
