Headlight intensity in auto mode - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2011, 02:05 PM   #1 (permalink)
View edge3333's Photo Gallery
According to my 2010 Highlander User's Manual, the headlights should run at reduced intensity during the day when in the auto mode. I've noticed that the intensity is always the same whether it's day or night. The only difference is that the yellow side lamps turn on when the system senses that there is insufficient daylight. I've proven to myself that the intensity is always the same by "tricking" the light sensor in a dark garage using a high intensity spotlight pointed at the sensor which will cause the lamp display on the dash to turn off.
Has anyone out there experimented with their Highlander to see if the headlight intensity is actually reduced during daylight hours?
edge3333 is offline   Reply With Quote
Old 11-10-2011, 03:18 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
The DRL's are the lowbeam circuit and they run at something like 80% max power (my toyota docs say "8.47-12.6V" range of power for the DRL (opposed to 13.5'ish volts at full power). Its pretty close to full power. Most cars with DRL's run like 6 volts in the high beam circuit so its easy to see, I don't know why Toyota decided to use the low beam though (but that does force them to up the power to be visible during the day).
So they are going to appear similar, but it should be just a tad less (enough to not drastically shorten bulb life). I don't think its anything to worry about.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 11-11-2011, 04:50 PM   #3 (permalink)
Thanks for the reply. After experimenting again, I do see a slight decrease in intensity when in the auto mode and simulating daylight conditions.
