Originally Posted by ej063090
Has anyone used DDM Tuning HID kit in their Highlander? A co-worker has a 2009 Highlander and is looking for higher light output. I am thinking he would be better off with an upgraded headlight bulb, but he wants more info on the HID kits. I have the kit in my 2010 Corolla and it is great. I also suggested to him a fog light system, which greatly enhances vison when in use. Any recommendations?
oh boy...... dear god please stay away from HID in stock fogs (more on that in a sec).
-I have only ever used DDM tunings hardware in my highlander (i have had a 35 watt digital, 35 watt analog, and 55 watt digital (currently on headlights) ballasts). A lot of people say they are bad on reliability, but I have never had issues in the past 2-3 years. Compared to OEM ballasts, they warm up slower to full brightness, and draw more amps on start-up (wire-harness is a must with HID's). Some say reliability will be an issue, but again I have never once had my ballasts fail (Now my DDM tuning wireharness did, I made a custom one after that), and I have put them under abuse. Now their bulbs are another story. There are rumors that they only sell 3 colors of bulbs (even though their website says 6-7 different color temps). 4.3k bulbs are the brightest hands down, and is the color of OEM HID's. 5k is about 200-400 lumens less than 4.3k, 6k is FAR less. So for the sake of getting lumens stick with 4.3k or 5k. Though DDMtunings bulbs are questionable in that regard. I ordered 4.3k bulbs from them (during PnP age haha) and they were correct, my friend ordered 5k bulbs and they were more like 6k-7k. I think their 5k is actually a 6k bulb with a sticker on it for a 5k (there are threads on other forums about that). I would definitly stick with 4.3k if you order from them. (***Correction DDM's version of the 4.3k bulb is a 4.5k bulb, that is what I got from them***)
-putting HID's in halogen reflectors, you are going to blind everyone (ESPECIALLY fogs). The highlander fogs do not have a built in bulb cap. It relies on the H11's built in bulb cap to prevent glare. You put a rebased HID bulb in there (which do not have a bulb cap) and you have 2 highbeam housings on the corners of your bumpers, and it will blind everyone on the road. (I used to have PnP in both my headlights and fogs, I know from experience) The headlights aren't as bad with HID as they do aim more than the fogs (and have built in bulb caps), but its actually hurts your vision more. Halogen reflectors give a narrow beam over a distance, while hid projectors give a wide beam over a distance. If you put a hid bulb in the halogen reflector your going to get 2-3x as much light in that narrow beam. Your eyes are going to adjust to that very high foreground lighting and you will lose all vision to the sides + it will kill your distance vision.
- only way to correctly have HID's is to retrofit hid projectors into the headlight. Yes HID in halogen reflectors do put more light on the road, but only in a small area and it will be too bright in that area. The hid projector will take that light and spread it out real wide to even out the light output.
-I would say try upgrading the halogen bulbs (Osram Night Breakers are good, stay from slyvania silverstar ultra's, if you do get slyvania use the Xtravision's. From what I understand they are basically the silverstar ultra's without the blue coating (which kills lumens) in other words xtravision is brighter, but not whiter.) OR use a catz zeta sytem. Its basically ballasts for halogen bulbs, but you can use stock halogen bulbs. The ballasts input the ~13.5 volts from the car running and outputs ~15 volts to the bulb. It increase the lumen output ot around 2000-2500 vs ~1300 lumens stock.
Sorry if that came off as a rant hahaha didn't mean to, just trying to say everything that needed to be said
