Toyota's Recommended PSI for 17" tire/wheel setup? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2011, 01:28 PM   #1 (permalink)
View Nominee's Photo Gallery
Hey all,
For all the highlander owners with the 17" tire setup (my limited came with 19"s but runnign 17" for winter) - what is the recommended tire PSI?
P245/65R17 = ?? PSI
Thanks for your help
Nominee is offline   Reply With Quote
Old 11-22-2011, 02:15 PM   #2 (permalink)
View nov0798's Photo Gallery
I run 32 on everything! 14s, 17's, 19's. The tire still has to support the same weight regardless of the size of the wheel.
nov0798 is offline   Reply With Quote
Old 11-22-2011, 02:21 PM   #3 (permalink)
Yes - but due to sidewall support etc, the PSI will be different.
i.e. on my BMW M3, the 19" setup requires 33psi. Whereas the 17" winter setup requires 37psi.
So - looking for the Toyota recommendation on the stock 17" tire size. My limited only lists the recommended psi for the 19" setup on the door jam sticker
Old 11-22-2011, 02:27 PM   #4 (permalink)
View jack63's Photo Gallery
Canada
I got mine at 35psi, just installed over the weekend a RAV4 17" steel wheels with Blizzak 245/65/17
jack63 is offline   Reply With Quote
Old 11-22-2011, 02:37 PM   #5 (permalink)
It really doesnt matter! What matters is the MAX load the tire can handle, and yes this will require a different PSI based on the tire size. I assume you arent placing these tires anywhere near their max load, so run them at whatever pressure you want not exceeding the max, and youll be fine.
Anyway look in the manual, it list the tire sizes, and recommended pressures for all size tires that came on that vehicle! It should also be located on the inside of the drivers door jamb.
Old 11-22-2011, 03:06 PM   #6 (permalink)
Beginner
View Subaryota's Photo Gallery
Originally Posted by Nominee View Post
Hey all,
P245/65R17 = ?? PSI
Similar situation for me (I have the Sports package - same wheel/tire combo as the Ltd). I'm running 35psi on my 17" snowtires.
FYI, I ran the 19" at 35psi as well..... just trying to squeeze a few more MPGs out of the tank.
Cheers
Jason W
MY03 Green RAV4: the utility vehicle
MY06 SGM Subaru WRX Wagon: power + suspension + brake upgrades + tune by Diebold Motorsports = all weather interceptor
MY12 MGM Highlander Sport: aka "The Bus"
Subaryota is offline   Reply With Quote
Old 11-22-2011, 04:23 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
I've got 43,000 now on my OEM Duelers with even wear and tires kept at 35 PSI.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-22-2011, 06:11 PM   #8 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
The perfect pressure could get very complicated to figure out and would vary with speed tire design and temperature. 35 seems a good compromise between too hard and economy.
Ralph6410 is offline   Reply With Quote
Old 11-22-2011, 11:16 PM   #9 (permalink)
Gameroom cash: $166987
View thenebula873's Photo Gallery
I like a stiffer ride so I usually keep my tires between 35 and 37 PSI. I wouldn't go below 32 so you won't accidentally hit the TPMS sensor threshold.
thenebula873 is offline   Reply With Quote
