2008 Highlander Limited Radio Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2011, 07:58 AM   #1 (permalink)
View AnthonyF's Photo Gallery
Hi,
Does anyone have step by step instructions to remove the JBL radio from the dash. I have to install another Sirius unit to replace the one thats not working properly. Thanks for your help.
Anthony
2008 Highlander Limited - Pearl White - Fully Loaded w/o Navigation
2009 RAV4 - Sandy Beige - Fully Loaded w Navigation
AnthonyF is offline   Reply With Quote
Old 11-27-2011, 03:21 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
If no one has the instructions available there are two possible options. You could either try contacting member nibalm3 who did a JBL swap out in one of the DIY Maintenance and Mods sticky, or you can purchase a two day membership for $15 with Toyota's TIS which should have the full set of instructions.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-27-2011, 04:33 PM   #3 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
These are from the common modification sticky
headunit removal:
DIY Radio and Subwoofer Install in 2009 Toyota Highlander
XM sirius tuner:
http://sumbiz03.home.comcast.net/~su...M_SatTuner.pdf
The XM/Sirius tuner is under the driver seat, it is a grey box about 4"x8", only held in with simple screws. Its easy to remove.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
