major water pump failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2011, 05:07 PM   #1 (permalink)
View frotou's Photo Gallery
Canada major water pump failure
71000 km for my 2008 . Water pump is about to have MAJOR damage (pulley moves a lot when I move with hands.). Also very noisy at idle .
I want to know if the water pump is cover by the engine/transmission waranty (100k km/5 years) ?
frotou is offline   Reply With Quote
Old 11-27-2011, 11:39 AM   #2 (permalink)
High Desert Hybrids, LLC
View Jennie_Eilerts's Photo Gallery
Water pump is a powertrain warranty item.
Do you have any coolant left? Usually by the time the shaft is loose, the seal is so bad that all fluid will leak out once the system is at full pressure.
Jennie_Eilerts is offline   Reply With Quote
Old 11-27-2011, 03:34 PM   #3 (permalink)
There is little leak of coolant , not that much . There is a splash of coolant behind the pump. It's very impressive how the saft is loose.
