Tpms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2011, 06:21 PM   #1 (permalink)
View guytdt's Photo Gallery
Tpms
Anybody knows the psi for the spare tire?
For 2011, all four tires are 30psi, but I'm not sure about spare, same?
I got TPMS light on and off for the last couple days depending on temperature or day/night. I checked and 2 are 29psi and 2 are 30psi. Spare is 34.
I make them all 32psi except spare I didn't touch it.
Now the light is on again. Will TPMS light on when it is too high?
guytdt is offline   Reply With Quote
Old 11-28-2011, 06:59 PM   #2 (permalink)
Gameroom cash: $159850
View Ralph6410's Photo Gallery
No the TPMs light only activates on low pressure. I seem to recall it is ~ 25 PSI. Your spare should be the same as the rest of the tires and at 30 you are lower than most of the HL members, the consensus seems to be that 35 is the sweet spot.
Ralph6410 is offline   Reply With Quote
Old 11-28-2011, 07:26 PM   #3 (permalink)
bschurr's Avatar
View bschurr's Photo Gallery
You may need to recalibrate...
2011 Highlander Limited - Loaded - Kid Hauler
2009 Infiniti G37 Convertible - 6MT - Summer Fun
1997 Jeep Wrangler - Foul Weather & Winter Beater
1974 MGB - Family Owned Since Birth - Garage Queen
bschurr is offline   Reply With Quote
Old 11-28-2011, 08:28 PM   #4 (permalink)
View mikmabz's Photo Gallery
You might wanna try this: ***READ FIRST*** Common Problems/Questions & Solutions
2009 Sandy Beach Metallic Highlander Sport V6 AWD
2011 Pyrite Mica Rav4 Limited I4 4WD ( wife's )
mikmabz is offline   Reply With Quote
Old 11-28-2011, 08:30 PM   #5 (permalink)
It is under "problems with solutions and explanations"
Old 11-28-2011, 09:06 PM   #6 (permalink)
View Ted Striker's Photo Gallery
Set them to 35, make sure the gauge you use is good. The cheap pencil gauges are notoriously wrong. Even as a pro I have to replace air gauges from time to time. Understand as temperature drops pressure drops. So 35 may seem high but if you fill them when the tire is like 65, 70 degrees by the time your tire hits 30, 40 degrees sitting all night your pressure will be like 32,33 psi enough to keep the light off. Nitrogen helps too, it changes pressure less than air and doesn't seep out of the tires as fast.
Toyota MDT
Ted Striker is offline   Reply With Quote
Old 12-02-2011, 07:04 PM   #7 (permalink)
View lispeej's Photo Gallery
Can the spare tire really trigger the tpms light?? I have a tpms light on too for the longest time now, but haven't thought of to check the spare yet.
lispeej is offline   Reply With Quote
Old 12-02-2011, 09:55 PM   #8 (permalink)
The transmitter in the spare responds exactly the same as the other 4. Your car (unless it is a hybrid) does not know which transmitter is sending a low pressure alarm.
Old 12-02-2011, 11:15 PM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
Yep, seems to be the most common reason for the TPMS light coming on with owners.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 12-03-2011, 09:37 AM   #10 (permalink)
will check today...thanks.
Old 12-04-2011, 09:14 AM   #11 (permalink)
Took my car into the tire shop to have all four tires checked. The spare was definitely down 10 psi of air. After getting that taken care of, it took care of my tpms light.
Old 12-04-2011, 12:29 PM   #12 (permalink)
And another success story for the rational for TPM's
