2012 HL rear heat problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2011, 02:36 PM   #1 (permalink)
View Yota Fan's Photo Gallery
I just pruchased a 2012 HL for my wife and it seems the rear heat is not working. Regardless of if we turn the rear heat to Max from the front or rear controls the rear vents only produce luke warm to cool air. Has anyone else had this issue? The controls have so many options I thought I would post here before taking it do the dealer to make sure we don't have something set wrong. The manual was odd as well since it does not address rear heat, just "air conditioning" which may be the new terminology for interior air modification whether its heating or cooling. Thanks for any feedback!
Yota Fan is offline   Reply With Quote
Old 12-07-2011, 04:57 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
Two past threads for you to peruse:
Rear Top Heater Vents doesn't seem to blow hot air
Cold Air Coming Out From Rear Heater, 2010
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 12-07-2011, 05:28 PM   #3 (permalink)
View shellback's Photo Gallery
Have you pushed the "Rear" button on the dashboard? I had a similar experience with rear A/C not working until that button was pushed. I think that button enables and disables the rear control panel.
shellback is offline   Reply With Quote
Old 12-07-2011, 08:33 PM   #4 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
are you checking the correct vent???
the ones under the front seats that aim toward the back are controlled by the front system.
There is a single large vent behind the passenger 2nd row seat (kind on the side wall in front of the wheel well, blows into the 3rd row foot area) that is the rear heat vent (when not forcing the system to send the rear heat to the top vents).
Mine gets VERY warm, but only once the engine is fully warmed up, its lukewarm to cool until them.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 12-08-2011, 02:38 PM   #5 (permalink)
Originally Posted by TrailDust View Post
Thank you very much for the links TrailDust! I didn't catch these when I was searching, they were very helpful.
Old 12-08-2011, 02:43 PM   #6 (permalink)
Thanks for the information. We had been checking the overhead vents thinking the system should provide heat through all rear vents as indicated on either the front or rear control panels (depending on settings). The vent behind the passenger second row seat does produce hot air but I still think the others should as well. Apparantly that is not how the system is designed. The overhead vents do blow cold air when the A/C is on so apparantly that is the intent of the design.
Old 12-09-2011, 12:32 AM   #7 (permalink)
sweeneyp's Avatar
due to the tightness on space in that back panel area where the rear AC is stuffed, it might be designed that way (heat only to lower vent). I'll look through the toyota docs I have on the rear AC and post if I find anything that confirms or denies that.
