Can I Tow without Tow Pkg? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2011, 12:01 PM   #1 (permalink)
View mtran868's Photo Gallery
I have a 2008 Toyota Highlander. It has no tow pkg. The Highlander with tow pkg can tow 5k lbs. I've been towing my rig (2011 MPG 3200 lbs loaded) since May 2011 without problems but haven't gone farther than 30 miles one way.
I've been thinking about adding a transmission cooler. Will this be sufficient? Or do I need to get a new vehicle? I want to go on longer trips but not sure how the Highlander will handle it.
mtran868 is offline   Reply With Quote
Old 12-19-2011, 12:39 PM   #2 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
This puts you into a service service category.
But, you can tow without the tow package. The owners manual should give you the weight limit.
You should install a transmission cooler.
deadrx7conv is offline   Reply With Quote
Old 12-19-2011, 06:31 PM   #3 (permalink)
Gameroom cash: $363535
View newsrv's Photo Gallery
Toyota spec for the 08 without the tow package is 2,000 pounds. The transmission cooler is a good addition. Maybe add an engine oil cooler. Does your trailer (MPD3200 ??) have brakes?
2008 Highlander AWD, Blizzard Pearl & Ash interior, loaded but no rear entertainment
newsrv is offline   Reply With Quote
Old 12-19-2011, 06:38 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $613331
View Zembonez's Photo Gallery
3200 pounds should be OK with good trailer brakes and a trans cooler. Pulling heavy stuff in a unibody FWD car spooks me though.
Zembonez is offline   Reply With Quote
