U-Haul Hitches - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2011, 04:54 PM   #1 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
U-Haul Hitches
Well I just got a U-Haul hitch installed on my highlander 2 days ago. (I had to leave on a trip to Austin, TX with a trailer and realized I would be driving my highlander instead of my normal tow vehicle 2 days before I planned on leaving ) Anyway, I would have ordered from etrailers, but went to U-Haul since they had my hitch in stock at my local location and had no time to order.
Anyway, point of this post, I had seen online that some people consider U-Haul parts to be cheap and fail quickly, I just wanted to post this to point out the opposite.
I payed $203 for the hitch, install, and lifetime warranty. (hitch was 150, install was 30, warranty was 5, + tax) U-Haul actually uses Curt Hitches, then just sticks a sticker on it (can't remove or you void your warranty). The one Uhaul installed is the same as this one (http://www.etrailer.com/Trailer-Hitc...cleid=20087962) So they don't use cheap hitches they make themselves, they actually use quality aftermarket equipment.
As for wiring, They didn't stock the quick connect for the tow-prep package pre-run wires at my location, so I can't comment on that, but I did get this generic trailer light wire harness (http://www.uhaul.com/MovingSupplies/...odule?id=13612). I payed $43 for the module and installed it myself (U-Haul wanted $60 to install wiring). It basically has a 12v+ line (suppose to go to the battery, but I had amp wires I could tap into), ground, a wire to tap into the brake bulb + line, 2 wires for both L & R turn bulb + lines, and running lights + line tap (I used the 3rd pin on the brake bulb, the ones that controls the dim lights when the headlights are on. Its the thinnest wire, the actual brake light wire is the thicker one.) Anyway works great/as suppose to. I installed the module where the socket is for the tow-prep package flat4 connector is (under the cargo bin on the left side of the trunk.) The module has plenty of wire to go through the rubber grommet there then reach the hitch with plenty of slack. I looped the extra around the bumper as it was too long. Plus the flat 4 connector on this has LED indicators on it to let you know its working without a trailer.
Anyway just posted this to let people know you don't have to order everything online (for aftermarket). U-Haul does have the quality parts (and their hitch was acutally cheaper than etrailer)
As for the towing, I was towing a standard U-Haul 5x8 trailer (my ball mount had a 2" drop, and it was too low with all that weight, had to flip it to be a 3/4" lift to have the right ride height. That is the only problem I see with these aftermarket hitches vs OEM, they do sit low.) that was FULLY loaded (probably close to overloaded) + the back of the highlander was totally filled (rear suspension was almost bottomed out due to weight). Went about 75 mph the whole way, got about 15 mpg in the flat area's (Arkansas-Texas) and around 13.5 mpg in the hilly parts of Tennessee. The highlander tows like a champ, even in the rain I ran into in Austin (stupid duelers spun like crazy when stopped on a hill trying to accelerate took awhile to get moving again, though that was probably because it was FWD instead of AWD with all the weight in the back.). On flat ground it would hold 5th gear fine at 75 mph, but in the hilly sections it would drop down to 3rd to hold speed (I kept the S shifter in 4 during those times). And the brakes are plenty strong to handle that kind of load. Considering trucks and full size SUV's get low mpg (my normal tow vehicle gets 15 mpg highway unloaded), I was more than satisfied with the HL's performance as a replacement.
anyway just a "for what its worth" post haha
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 12-29-2011, 01:39 PM   #2 (permalink)
View nannahill's Photo Gallery
Good reading. I have a U-Haul hitch on mine. No complaints either. It's well built and sturdy. I also like the fact it's a 2" version vs a 1.25" version. Haven't towed with it yet but it works well with my Yakima bike carrier.
'09 Highlander Ltd
nannahill is offline   Reply With Quote
Old 12-31-2011, 10:09 PM   #3 (permalink)
Kohari1
jpntaka's Avatar
View jpntaka's Photo Gallery
Nice!! I was thinking about getting a hitch on mine as well.
If the U-Haul one is not that bad, I might just get it.
Thanks for the post.
'08 Highlander Hybrid Limited w/ Custom Headlights & Philips LED DRL
jpntaka is offline   Reply With Quote
Old 01-03-2012, 09:18 AM   #4 (permalink)
Dergara's Avatar
View Dergara's Photo Gallery
Question: Does the 2010 HL have those under body plastic pieces as a 2011-12 that need to be trimmed in order to install a hitch? If so did UHAUL trim those or did they just remove them?
Dergara is online now   Reply With Quote
Old 01-03-2012, 11:15 AM   #5 (permalink)
sweeneyp's Avatar
the 08-10 do not have those plastic lower bumpers like the 11-12's do, but it does have plastic covers UNDER the car (to the sides of the spare tire). You have to remove those for any aftermarket hitch. The passenger side one is re-installed as it doesn't have to be trimmed. The driver one does have to be trimmed. Uhaul did not trim/install that side, I just asked to have that panel back and I plan on trimming and re-installing it when I get a chance.
Old 01-03-2012, 12:08 PM   #6 (permalink)
Dergara's Avatar
Thanks for the information.
