XM Radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2011, 09:58 AM   #1 (permalink)
View dallen3737's Photo Gallery
XM Radio
Merry Christmas, Happy Holidays to all
I tried checking other posts, but did not see a clear answer. I just got a XM Satellite subscription for Christmas. I have a 2008 Sport with the factory NAV and wasn't sure if I needed to buy another antenna for the satellite radio to work. I don't have any external antennas on it
Thanks
dallen3737 is offline   Reply With Quote
Old 12-25-2011, 11:08 AM   #2 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
http://www.trdsparks.com/install/PT546-48080inst.pdf
I vaguely remember a member here doing an install. Search for the thread. It requires a little bit of work.
deadrx7conv is offline   Reply With Quote
Old 12-25-2011, 11:19 AM   #3 (permalink)
Thanks, awfully complicated since it is already supposed to be intergrated into the factory stereo. I thought at worst I would just need an external antenna.
There is a SAT/AM button on it, but I have not been able to find the radio code. It says to tune to channel 0, but I can't figure out how. The owners manual is not very helpful
Old 12-25-2011, 11:48 AM   #4 (permalink)
Why is it when I push the AM/SAT button it only stays on AM, it won't pull up the SAT screen. I do have the factory NAV system
Thanks
Old 01-05-2012, 11:58 AM   #5 (permalink)
View cu52's Photo Gallery
Thanks
Sounds like you are missing the XM radio receiver and install kit. I believe two part numbers are needed for that install. IF the receiver was installed it would give you XM channel 001 (demo) and you could go to channel 000 i think to show the receiver code.
08 highlander
11 tacoma
cu52 is offline   Reply With Quote
Old 01-26-2012, 06:53 PM   #6 (permalink)
View mccartsj's Photo Gallery
I put XM in my 09 Sport with the unit from the dealer. On the sticker, Toyota says it's "XM ready" or something similar. You have to purchase the satellite radio tuner unit that is installed in the dash - behind the glove box. I did see find a PDF to do it yourself, but after looking through the steps, I opted to have the audio shop that the dealer uses here in town install it. Nothing will happen when you press the SAT button unless this unit/box is installed.
09 AWD HL Sport - Cypress w/factory hitch, tow package
mccartsj is offline   Reply With Quote
Old 01-26-2012, 09:04 PM   #7 (permalink)
Gameroom cash: $108900
View abimom's Photo Gallery
I installed the XM in my wife's 08 years ago. You need to get the kit and install the reciver under the drivers seat and run cables to the radio and mount an antenna.
abimom is offline   Reply With Quote
