Brake fluid.
It depends on the type of brake fluid used by Toyota and if the Maintenance menu was a dealer menu or a Toyota Maintenance book schedule
The reasoning used to be that Brake Fluid attracts moisture and in turn could cause problems with the brake caliper pistons
One rule of thumb I found
Special tools and chemical test strips are available for testing brake fluid, but since brake fluid naturally attracts and absorbs moisture (hygroscopic) it will need to be changed. The color of the fluid is a good indication of its current state. Check it yourself with a flashlight; yellow to amber means it's OK for now, amber to light brown (or darker) means it is time for a change. Some cars will soil the brake or clutch fluid faster than others. Driving habits and road conditions will also have an effect on fluid longevity.
Would be interested in finding out if this is a Toyota of Canada thing in your maintenance manual.
My 2008 maintenance Manual has 60,000miles or 72 months Driving while towing:
Replace automatic transmission fluid
Replace front differential oil
Replace rear differential oil (4WD)
Replace transfer case oil (4WD)
Didn't see any recommendation if you are not towing or operating in harsh conditions.
Some owners like to replace the fluids on a more frequent basis but the US Toyota minimum service does not say it is required.
