Yes, I'm looking at the reservoir tank. When I last checked the tank, it was about halfway between "full" and "fill." Now it's at the "fill" line. Even after the engine (and coolant) is warm, it stays at the "fill" line.
I'm having the Toyota dealer check it out tomorrow. My understanding is that the cooling system is a closed system and very little, if any coolant, should be "lost". In fact, isnt the system pressurized?
Originally Posted by dallen3737
Are you looking at the level in the reservoir tank? The level in the tank will be lower when the engine is cold. A little loss is normal, you can usually smell an antifreeze leak before you see it.
