Engine light on after air filter replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2012, 04:38 PM   #1 (permalink)
View Ruckin69's Photo Gallery
Do aftermarket air filters cause the engine light to come on? I had to disconnect the connector on top of the airflow box too to gain access. Would that cause it? I went back to the dealership and they said Toyotas are very touchy and talked me into a Toyota air filter, ($5) more then the aftermarker (no biggy) and after I installed it and pusted the odometer in and started it, the warning light went away. Saved myself $30 on a them doing it. Any opinions?
Thanks
Ruckin69 is offline   Reply With Quote
Old 01-09-2012, 05:53 PM   #2 (permalink)
View jimmiejo's Photo Gallery
Replaced mine with a Fram purchsed from Walmart several thousand miles ago...never got an engine light, Same on my Tacoma no problems. May have been a dirty connector.
jimmiejo is offline   Reply With Quote
Old 01-09-2012, 05:58 PM   #3 (permalink)
Got it. Maybe it was because I disconnected that connector.
Old 01-09-2012, 10:19 PM   #4 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
Was it this you unplugged?
That is the Mass Airflow Sensor. If you unplug it and start (even just turn the car on, not crank) the car its going to throw up a warning light. It would go away after you have driven some with the sensor reconnected.
not sure why you would have to unplug it to change a filter though...
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 01-10-2012, 08:44 AM   #5 (permalink)
Yep. Thats what I unplugged to get more access to the filter. The light went off when I turned on the car holding the odometer button in. Great trick!
Old 01-10-2012, 11:41 AM   #6 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3631850
I have to disconnect the MAF as well when I open my air box, but I've never had it throw a light. Glad to know the reset worked fine for you.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 01-11-2012, 08:11 PM   #7 (permalink)
View nov0798's Photo Gallery
Check and make sure you plugged in the 3 vacuum hoses back into the air box.
Sweeneyp:
What is that thing on the top of your airbox on the right side? Mine does not have whatever that is??
nov0798 is offline   Reply With Quote
Old 01-11-2012, 08:47 PM   #8 (permalink)
sweeneyp's Avatar
that picture is 2 years old. Its an old DDMTuning 35 watt HID ballast from my PnP HID days.
