Originally Posted by TrailDust
Hmm, I don't experience that. Have you tried the battery disconnection/ECU reset thing? Having your Highlander relearn your shift points might make a difference....
Likewise (the quote). almost sounds like you are wanting it to down-shift to accelerate (at hw speeds), but only pushing the pedal a little of the way it needs, I've never had that happen
So they are saying because the shifter's are less intuitive (the sideway slide on our HL's vs single forward motion), it can cause people to get confused in a panic situation? That seems kind of extreme in my book. With ours, I just push at a slight angle and it will go along the "path" on its own, I don't have to methodically think about it. So I'm not sure how much I get that point. Nice to see though that if you accidentally shift into R or P the transmission won't do anything (I've had a friend who put his car in P while going forward, was rewarded with a nice grinding/slipping sound from the tranny as the car front wheels semi-skidded to a stop. I have always been cautious after that). But what I never understood was why they couldn't shift to N. Its straight forward on the shifter so how could that be confusing?!?
But it was nice to be able to get some data, I found it interesting it took 270lb of force on the brake pedal to prevent movement without vacuum. I don't think everyone could put that kind of force on a pedal(granted they did say no vehicles were totally without vacuum ever).
