Geez, who knows. I had some rattling and found a small 7 or 8 mm extended socket on the floor under my 3rd row....some factory worker in Japan is missing a socket.  I also noted this weekend that under the seats, there are cuts or openings in the carpet through which something could pass, end up on the steel floor underneath and make unrelenting noises, just frequently enough to drive you nuts. You may want to check that out. Best way is to have a 2nd person in the vehicle who can try to pin point the location. Ultimately, it may in fact be mechanical.
Good luck.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
