Lift gate pistons - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 06:20 AM   #1 (permalink)
summerwind's Avatar
Gameroom cash: $450530
View summerwind's Photo Gallery
Lift gate pistons
Anyone know if a source for replacement pistons?
Dealer cost was around $300 for two.
The liftgate motor only raises the the lift gate half mast and I have to push it up the rest of the way.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 01-19-2012, 09:57 AM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
looks like they got different types (if you have navigation (which ur signiture says you don't), power liftgate, or no power liftgate)
anyway, here is a link to a site that has all of the different variants.
http://www.trademotion.com/parts/200...ift%20cylinder
You might see if you can get the P/N from the dealership. You can search for part numbers on that website to find the exact piston you need. I would never have thought there would be a specific piston if you have navigation vs not and power lift gate (well that one is a little more understandable).
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 01-19-2012, 11:09 AM   #3 (permalink)
summerwind's Avatar
Thanks much.
Didn't realize there was so much variation.
Mine is Power lift gate/ no nav
Old 01-19-2012, 09:47 PM   #4 (permalink)
View dtown40's Photo Gallery
At first I thought a power lift gate would be a nice thing to have, but after having read so many problems with them, I guess I'm glad I got the manual instead. More goodies mean more things to go wrong. I guess my dad was right this time.
dtown40 is offline   Reply With Quote
Old 01-19-2012, 09:51 PM   #5 (permalink)
sweeneyp's Avatar
dtown40, you know summerwind is talking about the gas lift pistons on each side of the tailgate, not a power lift gate component? All HL's have them power liftgate or not
Old 01-21-2012, 06:04 PM   #6 (permalink)
View dallen3737's Photo Gallery
I had mine replaced on my 2008 2 month's ago under the extended warranty. The dealer said it would have been around $300 without it.
dallen3737 is offline   Reply With Quote
Old 01-22-2012, 07:02 AM   #7 (permalink)
summerwind's Avatar
Yeah they are expensive.
You would think for the cost of the pistons they would last longer
Old 02-08-2012, 05:00 AM   #8 (permalink)
View 60DRB's Photo Gallery
...and WHEN the liftgate motor fails, that part is $1200.00 plus tax and labor. Enjoy that high quality.
DRB aka The Grinch
60DRB is offline   Reply With Quote
Old 02-08-2012, 08:22 AM   #9 (permalink)
becks's Avatar
Gameroom cash: $126215
View becks's Photo Gallery
Just out of curiosity 60DRB, which HL do you own, and have you had this problem ?
08 4WD HL Limited, Magnetic Flint/Ash Leather, Toyo OC HT's 255/55/19's, European Horns, Extended Step Plate On Rear, DeBadged All Around. No NAV/DVD, OEM Hitch with Color Matched Fascia.Höen Endurance Amber Fog Light Bulbs.
__________________________________________________ ___________________________________
becks is offline   Reply With Quote
Old 02-08-2012, 11:20 AM   #10 (permalink)
View Tomrock's Photo Gallery
Anyone know where the power liftgate motor is located? Just curious.
A little bit off topic, but if the motor fails can the liftgate fall back to being used manually in a pinch?
Tomrock is offline   Reply With Quote
Old 02-08-2012, 12:23 PM   #11 (permalink)
sweeneyp's Avatar
its in the top left corner there behind the panel, that's the power lift-gate arm sticking out.
It should open with the motor not working, I never use the power lift-gate on mine and it doesn't sound like its turning the gears of the motor when I'm moving it. The motor might disengage somehow from the arm of the power lift-gate when not in use kinda like how a starter works, but I'm not sure. Also it works when it has no power (no battery connected) it can still be opened and closed.
60DRB...$1200 is a ton for just a small motor. I would have just ordered the motor online (its $950 for the motor, or found a junkyard. should be plenty of salvageable 08+ HL parts by now) and installed it myself and save some cash, its only 4 bolts that hold it in place. Gotta love OEM prices
Old 02-08-2012, 01:13 PM   #12 (permalink)
Thanks for your reply!
So to operate a power liftgate manually you can just use the handle on the back?
Again sorry for the hijack these power liftgates make me kind of nervous.
Last edited by TrailDust; 02-08-2012 at 02:33 PM. Reason: Photo removed from quote
Old 02-08-2012, 01:16 PM   #13 (permalink)
sweeneyp's Avatar
You open/close it just like a normal tailgate on any car (handle, just grabbing the tailgate itself etc...), its just when you activate the power tailgate you will hear/feel it catch and it will close/open automatically. It does not hamper normal tailgate uses/operation at all
Old 02-09-2012, 06:39 AM   #14 (permalink)
summerwind's Avatar
For my 2008 HL Limited with power lift gate the part numbers are.
Left Hand side 689 604 9315
Right Hand side 689 504 9315
http://www.toyotapartswholesale.com/
$112.59 each
Will post how they install when I get them
Old 02-11-2012, 01:10 PM   #15 (permalink)
We have a '09 Limited, bought new. After about twenty months the rear hatch acted up when my wife was picking up our grandkids accross state. It went up and down several times and would not latch down until about the tenth attempt. Worked fine for several months after that incident, so we pretty much forgot about it. Then it did that again and my wife took it into the dealer and they said it just needed an adjustment and was fine. Then about 2 or 3 months past the waranty expiration the hatch did the same thing again, only this time when it finally latched down it made a loud thumping noise and the hatch was pulled down hard toward the driver side and was jammed shut completely. This time when I took it to the dealer it took the mechanics about an hour to get it open. I was told the electric motor was bad and the replacement part alone was $1200.00. Any other questions?
DRB aka The Grinch
