Pre wired side mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 09:21 AM   #1 (permalink)
View 2UTA's Photo Gallery
Does anyone know if a HL 2008 base model US made is pre wired for heated side mirror.
Thanks
2UTA is offline   Reply With Quote
Old 01-19-2012, 04:12 PM   #2 (permalink)
View cu52's Photo Gallery
Take off the door panel and look for the round plug. 2nd image in the link: Puddle Light Mirrors on Base Highlander?
Should take 10-15 minutes if you are handy.
Door panel removal.
1 Remove cover behind the door release lever, remove screw.
2 Remove door pull handle trim piece,
3 Remove screws top and bottom
4 Use a flat pry bar covered in blue or other tape to protect paint finish and pry the panel from the door skin.
5 pull door panel from skin up (easier to do with window down).
If more instructions are needed search.
08 highlander
11 tacoma
cu52 is offline   Reply With Quote
