You can see the engine mount between the radiator and engine block, towards the bottom of the engine bay. A flashlight should give you a good view of vacuum hoses. Trace them up to the top of the engine where they join up with other hoses and valves.
EDIT: I can't see how an MIL would get set for the engine mount, but it might get set if a shared vacuum hose was preventing say purge from happening.
I believe the timing belt is removed for the full Monty VVti service bulletin. It's possible that one of the cam timing is mechanically incorrect, which would make it idle badly, among other ills. Don't know whether the ECU can detect say one tooth off for one of the cams; i.e. an MIL code may or may not get set for something like that, but it's worth getting the code read.
'08 Highlander Base with goodies
'02 Highlander V6
'01 Honda Civic
'93 Camry LE V6 (departed)
