2012 Highlander LED DRL? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2012, 05:05 PM   #1 (permalink)
View racingdc9's Photo Gallery
Hello, new to the forums. I just bought a 2012 Limited and was wondering if the DRL bulbs can be changed out for LED's. I know that the DRL's are also the High beam. So can I put LED's in? I'm thinking if I did then I would loose the High beam? I also have an HID kit coming for the Highlander too.
Tommy
racingdc9 is offline   Reply With Quote
Old 01-23-2012, 06:40 PM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
the DRL uses the actual high beam bulb, so if you were to put a led bulb in there, you would lose all your highbeam functionality. LED's just don't put out enough light to be a viable headlight bulb replacement. I would stay away from that, and to TN!
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
Old 01-24-2012, 03:40 PM   #3 (permalink)
Thanks Sweeneyp
2012 Highlander Limited
