Painting plastic parts question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2012, 01:15 PM   #1 (permalink)
Dergara's Avatar
View Dergara's Photo Gallery
I have some color keyed fender flares for my 2012 HL and want to paint the bottom of them to line up with the unpainted black plastic parts of my vehicle.
My question is, what do I need to do to prep them, and what kind of paint should I use. I believe the color will be Matt Black?
Examples I found on Ebay are below. The bottom link is how I want them to look.
BEFORE:
http://www.ebay.com/itm/260820498323...#ht_500wt_1156
AFTER:
http://www.ebay.com/itm/260722046243...#ht_500wt_1413
Thanks
2012 HL Base V6 4X4 Classic Silver Metallic. W/ Tech, Cold, and Towing package. Camry Horns Low/High, Michelin LTX M/S 245/65/17 including spare, Factory Trailer Hitch and Harness, Toyota Color Keyed Fender Flares, Door Molding (install in spring)
Dergara is offline   Reply With Quote
Old 01-28-2012, 09:37 PM   #2 (permalink)
luck123's Avatar
View luck123's Photo Gallery
If you're painting on top of existing paint, then all you need to do is tape off flare leaving only area to paint exposed, sand it down with a very fine sandpaper (500+ grit), then clean it with a rubbing alcohol, re-mask and paint. I would recommend buying a proper automotive paint that is designed for plastic (ie. that has some flexibility to expand and contract with change in temps).
If you're painting directly on the plastic, I believe you need a special adhesion primer (depending on the paint).
Personally, I would take this to a body shop and have it done properly, with proper paint and baked on. Else, I guarantee that DIY paint will be more prone to chipping from road debris.
09 Black HL Sport, loaded Cdn version: AWD, bk leather int.
Mods: tinted windows; upgraded headlight and fog bulbs; bug deflector
; Ichiba 15mm bolt on wheel spacers, Pioneer FH-P8000BT head unit; Blaupunkt underseat sub, Viper 5901 security/auto start, stainless dual exhaust tip, upgraded horns.
luck123 is offline   Reply With Quote
Old 01-29-2012, 06:25 AM   #3 (permalink)
Dergara's Avatar
Thank you.
Old 01-29-2012, 10:52 PM   #4 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Why not color match the black to your vehicle color? It makes it look much better and not as trashy as the factory makes them look (no offense).
JMSinMD is offline   Reply With Quote
