Third brake light wiring question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2012, 07:20 AM   #1 (permalink)
Dergara's Avatar
View Dergara's Photo Gallery
There are two wires leading to the third brake light. Both are very thin, one is solid black, and one is white with a thin black line on it.
My question is, which one is the hot wire?
And what is the gauge of that wire?
Thanks
2012 HL Base V6 4X4 Classic Silver Metallic. W/ Tech, Cold, and Towing package. Camry Horns Low/High, Michelin LTX M/S 245/65/17 including spare, Factory Trailer Hitch and Harness, Toyota Color Keyed Fender Flares, Door Molding (install in spring)
Dergara is offline   Reply With Quote
Old 02-09-2012, 08:32 AM   #2 (permalink)
Never Done Modifying
sweeneyp's Avatar
Gameroom cash: $415485
View sweeneyp's Photo Gallery
It looks like the black is the + and white is the - (check with a multimeter to be sure). Its kinda strange, usually toyota is pretty good about keeping only the black and grey wires as ground wire, and the color ones as +, oh well (edit: also + line is usually a solid color, - is usually striped on most things I've worked on in my car).
As for gauge, I don't know exactly, I would guess probably 20-22 from what I've seen toyota use on other low power parts.
2008 Black Highlander Limited FWD
Nav (with override), Rear DVD | 900+ Watt Sound System | Headlight & Fog HID Projector Retrofit | LED Interior/Puddle Lights | Rattletrap Sound Deadener | Dueler HL Alenzas 255/55R19's |Updated Modification List
sweeneyp is online now   Reply With Quote
