exclamation light - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
post #1 of 9 Old 11-14-2009, 01:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
exclamation light
i just had this light turn on and stay on. im at around 40K miles. i read the manual and it says to have it checked by toyota if it stays on. anyone know what it could be?
luvx77x8o4 is offline
post #2 of 9 Old 11-14-2009, 01:56 PM
sparkyca's Avatar
Quoted: 0 Post(s)
Hello . I believe it was that light that came on when our /08 highlander had approx 24000 km on it. I contacted our dealer and they had it towed there. They replaced an oxygen sensor and problem solved. Turned out we probably could have drove it there, but they did`nt want to risk damaging something, since we are leasing it from them. I would recommend calling your dealer for advise.
sparkyca is offline
post #3 of 9 Old 11-14-2009, 02:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
you think it's still under warranty? i don't have the paper work on me right now. i didn't buy extended warranty because i figured i always had good luck with toyota.
post #4 of 9 Old 11-14-2009, 04:06 PM
Toyota Traitor
Quoted: 11 Post(s)
It could be something simple. Mine comes on if I have low washer fluid or if there is a door open. Check your glass hatch (if equipped). Also, if you have the multifunction display the problem usually displays on the screen.
Also, sparkyca do you know if the Highlanders have an O2 sensor problem? I've got close to 20000 KM on mine now and the go ahead with the O2 sensor in my last Highander was unbelievable!
2015 Acura RDX V6 AWD Tech
2009 Toyota Tacoma AC V6 SR5 w/PP
2008 Honda Civic LX-SR
departed.. 2002 & 2008 Highlander V6 AWD..
AXMACD is offline
post #5 of 9 Old 11-14-2009, 04:17 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3723 Post(s)
Not saying you guys did this, but instead I'm throwing it out to other owners. If you get an exclamation mark warning make sure to verify which one it is: Inside a triangle it's the master warning light; if it's inside a cross-sectional tire it's for the TPMS system; and if it's next to a steering wheel it's for the electronically-controlled steering system.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline
post #6 of 9 Old 11-14-2009, 04:40 PM
Toyota Traitor
Quoted: 11 Post(s)
Canada
The light in the middle top portion of the instrument cluster is the general warning light indicating things such as open moonroof, open door, open glass hatch, low washer fluid..
This light indicates low tire pressure, or in my case no tire pressure sensors at all.
I know some cars have an indicator light that will come on if you have a burnt out light. I have never had a burnt out head/tail light (knock on wood) so I don't know what light would illuminate (if any) in this case. Maybe you should check your tail lights?
AXMACD is offline
post #7 of 9 Old 11-14-2009, 05:36 PM
sparkyca's Avatar
Quoted: 0 Post(s)
I havent heard of the oxy sensor being an issue. Thanks to all for the responses here. I ve also experienced the low tire pressure warning and finally figured out that the spare tire was low, and filling it up made that go away.
sparkyca is offline
post #8 of 9 Old 11-14-2009, 08:16 PM
Dman1's Avatar
Quoted: 1 Post(s)
Sorry to go off topic, but I have a question for you regarding your TPMS light. Is there a constant display on the MFD as well, or is this the only indicator for this?
2009 Highlander Limited
2005 Corolla CE, Canadian Edition, Silver with grey interior, automatic transmission, CD changer, cruise control, rear bumper protector.
Dman1 is offline
post #9 of 9 Old 11-14-2009, 08:33 PM
Toyota Traitor
Quoted: 11 Post(s)
This is the only indicator.
AXMACD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 2nd Generation (2008-2013)
User Tag List
Linear Mode Linear Mode
Back
