Dead battery or key fob issue? - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 2nd Generation (2008-2013) Forum dedicated to the discussion of 2nd generation Toyota Highlanders.
post #1 of 16 Old 01-22-2011, 01:36 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I have quite the frustrating situation at the moment. I can't start my Highlander! There are many factors to consider but I'm not sure how to address the problem/s.
1) As I have 2 cars, the Highlander has not been driven in a few weeks so the battery could have naturally died also due to the extreme cold right now in the Northeast USA.
2) Vehicle does not recognize the electronic key fob (I have a Limited) so I used the manual "Pin" key but when I pushed the "Start engine" button, the screen gives out the message "key not detected".
3) The brake pedal feels very rigid which could mean the battery is dead, apart from the key issue.
Do I simply replace the battery of the key fob and hopefully, the vehicle's electronics would finally recognize the key, or do I go ahead and also find a way to charge the battery? Although a 2008 model, this car is rarely driven and has only done about 6000 miles! I imagine it would still be under warranty.
I am unsure of how to proceed. Has anyone gotten the same message on screen before? Thank you for any help out there!!!
Daimlerz
'08 Highlander 4wd Limited
daimlerz is offline
post #2 of 16 Old 01-22-2011, 02:29 PM
pestictide1480
Quoted: 0 Post(s)
I would ck. the battery first,If it a 08 the battery already 3 yrs.old and then not being driven very much it could be very weak.I would charge the battery and then have it load tested at a part store
pesticide1480 is offline
post #3 of 16 Old 01-22-2011, 03:39 PM
Resident Nutcase
sweeneyp's Avatar
Quoted: 1159 Post(s)
If the screen shows key not found then your car battery is not completely dead. If it was too low to start the car, you'd hear the starter make some kind of noise. More likely your key fob is dead. Here is how you start the car without the key fob charged. Put your foot on the brake and take the key fob and place the toyota symbol on it on the "start engine" button. After a sec or two you will here a beep and the light on the start button should be green. Hit that and it should start the car. If this happens the key fob is dead....if it doesnt start... both are dead lol. The brake pedal is rigid because the vacuum has depleted (i think thats what it is), and the engine hasn't been run to "recharge" the brakes...(i could be wrong on that though)
I hope this helps
Click Here for the Full List of Mods Done to My Highlander ---->>> 2008 FWD Highlander Limited
sweeneyp is offline
The Following User Says Thank You to sweeneyp For This Useful Post:
daimlerz (02-03-2011)
post #4 of 16 Old 01-22-2011, 03:45 PM
Need For Speed
arabianobsession's Avatar
Quoted: 1 Post(s)
1) Living in frigid temperatures is already extremely taxing on a cars' battery.
2) When a car is driven 6000 miles in roughly 3 years..that's 2000 miles per year. Not really enough to keep your battery charged.
3) When your battery is dead it will not obviously recognize your key or let you open the door by pushing the button.
I would get the battery tested. If it's dead, get it charged overnight. It may save the battery, it may not. For future reference, keep a trickle charger on your car's battery (parts stores, even walmart carries them), so the next time you go to start it, it's not dead. Otherwise, if you know it won't be driven for weeks at a time, disconnect your battery and bring it inside.
I live in Wisconsin, where currently as I write this it is 8 degrees outside. I have a Mustang that isn't driven in winter, but once a week I go out to the car, start it up, let it get to full operating temperature, and put it through the gears. Battery hasn't died on me this way, ever.
6 speed manual 2011 Camry SE
1995 Mustang-1994 Mustang GT
1985 AMC Eagle
arabianobsession is offline
post #5 of 16 Old 01-22-2011, 03:47 PM
Need For Speed
Quoted: 1 Post(s)
I hope this helps
No, that makes sense, as when the car is off and you keep pressing on the brake pedal, pretty soon you can't really do it anymore until you start the car again. All your vacuum has been depleted this way.
1985 AMC Eagle
post #6 of 16 Old 01-23-2011, 11:13 AM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3896 Post(s)
Be aware too that these OEM Panasonic batteries that come with the Highlander aren't worth crap. Mine lasted 18 months before failing and needing replacement.....
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now
post #7 of 16 Old 01-23-2011, 10:15 PM
Senior TN Member
Quoted: 2 Post(s)
I've replaced both remote batteries last year. I even keep spares in the glove box. Its too easy not to change the remote battery every 2 years. My Highlander also warned me when the keyfob battery was low.
Any vehicle sitting for weeks can have a battery drain down. Charge it and you should be fine. If the vehicle is regularly left alone for more than a week, you need to put it on a trickle charger, and use a fuel stabilizer to prevent fuel system problems.
If the vehicle is left outside, then a solar charger is worth getting. The VW ones from ebay are pretty cheap and work well when connected directly to the battery. I use a batteryminder solar panel one with desulfator for 1 of my cars which can sit for a couple months at a time. The battery is always perfectly charged when I do drive it. I have a Coleman unit on my other car. No desulfator on the Coleman but battery is always fully charged too.
deadrx7conv is offline
post #8 of 16 Old 02-03-2011, 02:15 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thank you everyone, most particularly to sweeneyp for the information and suggestions. I did try holding the dead keyfob against the start button and voila, it started the engine! That way, I was able to recharge the battery which was low but not entirely dead from not being driven in many weeks under frigid northeast temps of late.
I just replaced the cell batteries of the 2 keyfobs and now they work fine and most definitely are recognized again by the vehicle. Also, I ordered a trickle charger/maintainer to sustain the car's battery especially since I do not drive the Highlander that often. Thank you once again for the valuable tips!
Daimlerz
daimlerz is offline
post #9 of 16 Old 02-03-2011, 02:46 PM
Need For Speed
Quoted: 1 Post(s)
Seriously??? That's insane.....
When I worked back in the shop here at the dealership we'd get cars in ALL THE TIME that were 8+ years old on their original Panasonic batteries. Maybe their old school versions are much better than the current ones...
1985 AMC Eagle
post #10 of 16 Old 02-03-2011, 02:47 PM
Resident Nutcase
sweeneyp's Avatar
Mine had died already on my 08 (rather annoying only 2 years old)...it was replaced by an energizer one so hopefully it will last longer
sweeneyp is offline
post #11 of 16 Old 02-03-2011, 02:57 PM
Need For Speed
Quoted: 1 Post(s)
When I worked at Walmart I used to laugh at people coming in to buy the EverCrap (EverStart) batteries.....me and the guys would take bets to see how many months it would be before they were back for a different battery. It averaged around 6-7, lol.
1985 AMC Eagle
post #12 of 16 Old 02-03-2011, 04:53 PM
Do you feel lucky?
TrailDust's Avatar
Yep, I was not amused when it failed.
2002 Avalon XL
post #13 of 16 Old 02-03-2011, 04:55 PM
Need For Speed
Quoted: 1 Post(s)
I wouldn't be either, I'm sorry
If it makes you feel any better, sometimes when we go to deliver new cars, the customer tries to leave, and the battery is done for. Once it turned out to be the alternator on an 11 Highlander, one we had on the lot 10 days.
1985 AMC Eagle
post #14 of 16 Old 02-04-2011, 05:55 AM
Senior TN Member
summerwind's Avatar
Quoted: 13 Post(s)
Remember that if the battery goes in the SmartKey fob you still can start the car by holding the fob against the start button until the green light shows.
Just start as usual after that
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline
The Following User Says Thank You to summerwind For This Useful Post:
ThaiM (03-15-2015)
post #15 of 16 Old 10-31-2015, 11:03 AM
Gwagg
Quoted: 0 Post(s)
Bumping up an old thread. My father called about his 2015 Highlander today. He replaced the Panasonic battery and the car would not start. Lights, locks, dashboard all acted normal. The dealership told him on the phone he popped a fuse or the ECM, he is out of warranty. They sent a tow truck while I was reading the forum. I had my dad try to reinitialize the fob but to no avail. As the truck was being hooked to the tow truck, I read the above thread. I called them back and explained what to do. My father could not get it to work but the driver tried and he was successful getting it to start. The FOB has to be reinitialized after a engine battery replacement.
If you live in the south the heat will always destroy even the best batteries at 3-4 years. The only exception is my daughters Volvo whose battery is in the trunk and down in the wheel well. It never seems to get real hot there and very little vibration. That battery is 6 years old and still going. I have taken it to Autozone the last two years and it tests fine. I was so worried about it going dead on her that I have prepped her for the last three years that it will go. Now that she is a SR in college it will be a life lesson.
Gregg Wagner is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 2nd Generation (2008-2013)
User Tag List
Linear Mode Linear Mode
Back
