Re: Trailer wiring on 2006 Tacoma
On Sun, 23 Apr 2006 17:23:07 -0400, jaminn
<jaminn@remove.this.jaminn.org> wrote:
[color=blue]
>I finally got my pop-up in shape and was ready to wire the harness.
><snip>
>Jaminn aka Don Williams[/color]
Problem solved. Thanks for all the input, by the way. This afternoon
I checked all the grounds, even took one loose that was on a rusty
part and cleaned it, drilled a new hole and re-attached it. Then, I
applied 12 volts to each wire to make sure all the bulbs worked pn the
trailer as they should. All were fine. Hooked up the cable from the
truck to the camper and the lights still didn't work. So, I got to
looking elsewhere. I noticed on the cover of the truck connector that
it showed the location of the wires. I noticed right away that the
ground on the cable connector wasn't where the ground was on the truck
connector. So, it appears that I was confused by the pin out provided
with the cable connector (it is a 7 pin, round connector). Once I
figured out where the ground was, the rest of the connectors just fell
into place. All work fine now. I'm ready for next month when I will
be pulling the camper 1000 miles from GA to TX.
