I need help with trouble codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2005, 06:29 PM   #1 (permalink)
View khonesty's Photo Gallery
Gen1 I need help with trouble codes
does anyone know what the trouble code 56 is for on an 86 4runner? I've been searching the net but none of the lists I find have a 56 on them. I'm positive that is the code that I'm getting.
Thanks, Kivan
1986 4Runner 247,000 and counting
khonesty is offline
Old 10-14-2005, 08:02 PM   #2 (permalink)
Pipe Welder
banshee35's Avatar
View banshee35's Photo Gallery
according to my manual, there is no code "56" for any model year. there's a 5 and a 6 but no 56. 5 blinks means-Oxygen sensor signal.6 blinks-Ignition signal.
"Price reflects quality- You get what you pay for!"
banshee35 is offline
Old 10-14-2005, 09:13 PM   #3 (permalink)
View Sidney's Photo Gallery
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota/
http://members.igateway.net/~pscott/enginecodes.html
http://www.autobook.co.kr/data_links...uble_codes.htm
http://www.autoshop101.com/forms/h27.pdf
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
O
|\ __O
_|_| \
(\__/)
(")_(")
This is Bunny.Copy and paste bunny into your signature to help him gain world domination.
Sidney is offline
Old 10-18-2005, 07:18 PM   #4 (permalink)
thanks for the help guys
khonesty is offline
