Manifold bolts striped! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2005, 11:48 PM   #1 (permalink)
View dally41888's Photo Gallery
my manifold bolts are most likely striped and i dont really know why. i heard the exhaust getting a little louder and i tightened them one time and they were actually loose. i realizied the next time that they were striped and the worst one i drilland and tapped bigger but there are only one or two more but they are hard to reach with a big drill. any suggestions? thanks.
dally41888 is offline
Old 10-20-2005, 10:24 PM   #2 (permalink)
View rj998's Photo Gallery
I have a similar issue.. I have a 92 3.0 3vz, and lo and behold got it for free with blown head gaskets.. one exhaust manifold bolt stripped during reassembly.. it's mostly ok, but now in the colder days with windows up, I can hear it. it is starting to drive me nuts acutually. I have a heli-coil kit for it, and a dewalt right-angle drill, I think I can get to it with a shortened bit.
Is is fool hardy to think I can try using a t-handle on the bit and drill out the old threads by hand? it's an aluminum head of course, and it's not a fresh hole, just the threads that are there.. any thoughts?
rj998 is offline
Old 10-20-2005, 11:52 PM   #3 (permalink)
if you are going to tap it out once drilled it is best to do it with the t handle and i used one on mine the one on the top because there were two that were striped and it worked fine but there is no room for the drill on the bottom one i guess i need a riht angle drill... but yeh i would just use the t handle if you can
Old 10-29-2005, 12:42 PM   #4 (permalink)
I saw a decent t-handle at lowes for $6, I think it is worth a shot. they say to use kerosene on the threads when using the tap, and backing out every 1/4 turn or so, to let the cut metal out.. I'm going to try with a t-handle and a drill bit and the same approach. The key is to see if I can do it and get the heli-coil in there without taking the manifold off.
good luck with yours.
rj998 is offline
Old 10-29-2005, 06:43 PM   #5 (permalink)
Fageddaboudit!
bobad's Avatar
View bobad's Photo Gallery
rj988,
Beware of the wobbling T handle. It's almost impossible to hold it straight while turning it. Your hole will surely be bell-mouthed, egg-shaped, and oversized unless you take some kind of measure to keep the bit from wobbling.
Best of luck,,,
--Bob
Enjoying my silver 08 Tacoma Access Cab 4cyl 4a
bobad is offline
Old 10-29-2005, 11:49 PM   #6 (permalink)
true... good call. thanks for the advice
Old 11-01-2005, 09:10 PM   #7 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
I had the same problem and I just bought a longer bolt and was able to tighten it down. You might want to check and see if you could do that.
82toyo is offline
Old 11-01-2005, 11:09 PM   #8 (permalink)
exhaust manifold studs: m10x1.25 or m10x1.5?
bobad, thanks for the warning.
Does anyone know if the studs are M10x1.25 or M10x1.5? I think they're x1.5, the coarser thread. Trying to order the right helicoil kit.
thanks,
rj998
rj998 is offline
Old 11-02-2005, 07:35 AM   #9 (permalink)
i also tried that because i have can of old bolts and found one that matched the threads and was longer and it didnt work, it was just too stripped to grab. im not sure of the exact size either. i also just got a new gasket too b/c when i first start up it was leaking then went away once warm so the gasket should fix it. once i have it off to replace it tho i can tap out the other bolts that are stripped, i think its only one, for some reason it was the corner ones that stripped not any of the middle ones...wierd
