changed alternator - belt squeaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2005, 10:46 AM   #1 (permalink)
View chilli's Photo Gallery
I am just wondering if this means the belt is too loose, or too tight?
There is about 1/2 inch of flex when you push on the belt. The belt was changed last year when I did a tune up, and the belt is in "new" condition....
So again, too loose or too tight?
THX
chilli is offline
Old 10-17-2005, 03:47 PM   #2 (permalink)
The 2nd = Freedom
View 87yotaGOD's Photo Gallery
Sounds like your belt is too loose to me. Do you know how to tighten it? If you don't I can help with that.
87 4x4 Pickup
22R 5 speed manual
No current non-stock mods except a homemade bumper :P
Just added, brand new Pro Comp Series 97 Wheels.
87yotaGOD is offline
Old 10-17-2005, 04:11 PM   #3 (permalink)
Ya, I can tighten it more....I just set the tension based on what the manual calls for.
I'll tighten it s'more, and see if the squeak goes away.
THX
chilli is offline
Old 10-29-2005, 02:19 AM   #4 (permalink)
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
View rpmspeedyBlue's Photo Gallery
If you tighten your belt and it is still squeaking there is a spray that you can buy at the auto store or rub some beswax on the belt.
rpmspeedyBlue is offline
Old 10-29-2005, 09:29 AM   #5 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Do not use anything on the belt! They were not designed for it. It will degrade the life of the belt and temporarily mask the real problem. Is it the right belt? They come in different pitches. Was th sheave on the alternator the same as the original? If the sheave pitch is different on the crank and alternator, it could cause sqealing.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 11-01-2005, 11:17 AM   #6 (permalink)
its okay....I ended up getting a newer 4runner...
My 1990 has 350,000KMs and just needed way too much....I picked up a '94, so I can use my '90 for parts.
Thanks though....
chilli is offline
