Unusual High Idle Speed..engine stays at high rpms... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2005, 01:36 PM   #1 (permalink)
View 87_SR5's Photo Gallery
I was driving home last night (engine all warmed up)...cruising at 30mph, 2K rpms. I was coming up to a stop, so I put the clutch in and took it out of gear to coast up to the stop. The weird part was that the engine stayed up at the 2K rpms. I didn't touch the gas at all, and came to a full stop, where the engine was still at that high rpm. I sat for a second to see if it would go down, but never did. So I tapped the gas and then the rpms went back down to normal (the rpms went down much slower than usual).
I didn't know what to think, especially since the engine was fully warm (even though it shouldn't do that when the engine is cold). I tried to make it do the same thing, and it happened everytime I tried to do it.
That was last night...I haven't drove it today to see if it still does it. I am going to investigate it further to see if I can find anything, and check the computer to see if it throws any codes...
I just thought I would throw this problem out there to see if anyone can help. I will post anything I come up with after I check it out.
I don't think it is anything mechanical...as far as the throttle cable, etc...but I will check that out for sure.
87_SR5 is offline
Old 10-22-2005, 03:06 PM   #2 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
You need to clean your throttle body. Your throttle plate is sticking, and thats why your rpms hung up.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 10-22-2005, 03:31 PM   #3 (permalink)
Cap'n
I did have my throttle body off less than 6 months ago and cleaned it all (I had it off to fix/adjust the TPS)....and even before I had it off and cleaned, I didn't have this problem. I drove it yesterday during the day and didn't notice anything, but when I drove it last night, it started to do this.
I will certainly take a look at the throttle body though....
Thanks for the response.
87_SR5 is offline
Old 10-23-2005, 02:37 AM   #4 (permalink)
View qsd-dan's Photo Gallery
This happened to me when my dashpot started sticking (that brass looking valve that slowly brings the throttle to the rest position) I just squirted the hell out of the plunger with silicone spray and so far it hasn't given me any issues.
qsd-dan is offline
Old 11-25-2005, 11:02 PM   #5 (permalink)
toytruck89's Avatar
View toytruck89's Photo Gallery
check your motor mounts too and your trottle cable near the firewall... it might be sticking when torqued over or tugging at the firewall
toytruck89 is offline
Old 11-26-2005, 05:00 AM   #6 (permalink)
View texasjava's Photo Gallery
Canada
Hey, does outside temperature have anything to to do with the phenomenon?
texasjava is offline
Old 11-28-2005, 03:43 PM   #7 (permalink)
DCM
One with the farce
View DCM's Photo Gallery
Could still be the tps; I had to do mine a couple of times before it was finally good. As for that little dashpot under the throttle stop, take the screw right off so it's disconnected. It just holds the revs from coming down, and isn't even connected to anything.
DCM is offline
