Harmonic balancer repair sleeve/speedy sleeve (seal saver sleeve, balancer repair sleeve,crank seal saver) slides over shaft:
Felpro # 16214=$5
Future # 21-2514 (aluminum shaft sleeve included)
NAPA repair sleeve # 99177 (Mack PDC,National,Car Quest)
Pioneer repair sleeve (Silver Seal) # HB-4133
attached with some epoxy or use Loctite 609 or 242 or put some red RTV and fill that groove before you put it on also look in the yellow pages under “bearing suppliers”.
For a picture:
http://chicago-rawhide.com/auto/speedi/speedi.htm
Front crank oil seal (front input shaft seal):
Fed Mogul (National,Timken Seals) # 710345
Toyota # 90311-45014 (brown, 7 mm thick) & 90311-30115
Chicago Rawhide # CR17758 (9 mm thick) or CR550294 (7mm thick)
Beck Arnley # 0522144
NAPA repair sleeve # 99317(rear),list price $68.10>$33.19 net Canadian $ and the seal was $12.10
Rear crank seal Toyota # 90311-80010,90311-80001 (the earlier 20R & 22R seal),90311-80010 (is the improved version. It is made out of silicone and has double lip for better sealing).
This info provided by EB:there are 3 versions of the speedy sleeve:
1)one is light steel with spray chrome flashing(yuk)
2)one is steel with chrome plating
3)and the good ones are all stainless steel and they are made in Canada.
http://www.barneymc.com/toy_root/techneek/frntseal.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
O
|\ __O
_|_| \
