Engine Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2002, 01:58 AM   #1 (permalink)
View Luvs2Race's Photo Gallery
Engine Noise
I have a 1996 Tacoma Regular Cab 2wd and everytime i hit the gas and the engine goes over 2300RPM it makes a noise like the accessory belt is slipping. Its only after 2300RPM though. Its a 2.4L 5 spd. Any ideas?
Luvs2Race is offline
Old 12-03-2002, 03:00 AM   #2 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
what kind of noise???? any vibration???? coming from where???
any vibration on the throttle???
can't really pin point with out these info
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline
Old 12-03-2002, 09:30 AM   #3 (permalink)
No vibration at least i don't think so. But it sounds like the accessory belt is slipping. If i pull the throttle body cable(engine bay) the opposite way it will stop the noise.
Old 12-03-2002, 02:38 PM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
does it go *clink clink clink*? or
*geeeeeeeeeeeeee* or
*knock knock* or
*vewwwwwwwwwwwww*
....could be the water pump sometimes....bearing noise.
The AE92 Master
UniQue_N_RaRe
Old 12-03-2002, 03:33 PM   #5 (permalink)
its goes geeeeeeeeeeeeee* like a skreetching noise and its really loud.
and is the fan always supposed to be on??.
Old 12-03-2002, 07:35 PM   #6 (permalink)
Druken Postwhore
TRDragoon's Avatar
its your water pump then.....did you check the temp reading???.....if the fans stay on all the time...then ECT too hot....
if your engine was over heating, and if the fan didn't go off after key was turned off. then you better check your colling system...like water pump....
The AE92 Master
UniQue_N_RaRe
Old 12-04-2002, 01:36 AM   #7 (permalink)
Operating Temp is normal (Half way) and the fan even truns on when i first start it up in the morning
Old 12-04-2002, 01:47 AM   #8 (permalink)
Druken Postwhore
TRDragoon's Avatar
:o :o
hmmmmm.....
well....still take it to the shop....you dun really want to drive your car under normal temperature.
if you have A/C....maybe the clutch is rubbing against the shoe. and if your condensor fan was the one thats blowing...it could be your a/c system too
my guess are all wild at this point...take it to the shop and get it done properly...
The AE92 Master
UniQue_N_RaRe
Old 12-08-2002, 02:18 AM   #9 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
Are your belts loose? Try tighten them.
Steve
robinhood150 is offline
