Clutch Pedal Sticking 99 4runner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2006, 06:39 PM   #1 (permalink)
XPY
XPY's Avatar
View XPY's Photo Gallery
Canada Clutch Pedal Sticking 99 4runner
I have a 99 4Runner. The clutch pedal is sticking in the down position. It doesn’t do it all the time. Any ideas?
I'm still able to drive, at rest or moving I push down on the clutch and there's pressure. I'm able to put it in gear but sometimes the pedal releases back just a bit and stays down I have to use my foot to pull it back to normal. The rest of the gear shifting is fine. Sometimes when it's sticking in the down position it will slowly release back up. Is it possible one of the rubber bushings is grabbing the clutch shaft?
help me out please?
Thanks
XPY is offline
Old 07-31-2006, 04:50 PM   #2 (permalink)
View toysrus's Photo Gallery
It would seem you may have to replace the spring for it has become weak could remove the peadle from the truck and check the bushing replace as needed aply a small amout of grease in pin so as to let thing move easy .
toysrus is offline
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 06:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 08:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 05:16 PM
Clutch Pedal Sticking sritzau Celica Forum 5 12-02-2003 04:46 PM
