Securikey+
Valet mode: The LED button on the dash will turn on the valet mode when pushed in and turn off valet mode when pushed out. When in valet mode, all alarm functions are by-passed, except the panic function and door locks.
Intrusion notice: If your alarm has been activated, your truck's horn will honk 4 times when the vehicle is unlocked. Take note of the pattern of the LED button's flash on the dash.
If the LED is flashing one time...pause...one time...pause, then an intrusion attemp was made on the shock sensor.
If the LED is flashing two times...pause...two times...pause, then an intrusion attempt was made on the vehicle's hood.
If the the LED is flashing three times...pause...three times...pause, then an intrusion attempt was made through one of the vehicle's doors.
These intrusion warning indicators are stored in the system's memory and will be erased when the ignition is turned to the on position.
How to disarm the alarm if you lose your transmitter or if the battery is weak:
The valet switch can be used to disarm the alarm when can not disarm the alarm with the transmitter. Open the driver's door using the key. The horn will sound. Make sure the LED valet button is in the off (out) position, then turn the ignition key on. Press and release the LED valet button to the on ( in) position. The system will disarm and the vehicle can now be started.
Programming the alarm to arm/disarm silently:
Start with the LED button in the off position, then turn the vehicle's iginition key on then off.
Within 10 seconds, cycle the LED button to on then off three time (press and release the button 6 times)
If the chirps were off before you started, then you will hear 1 chirp indicating that they been turned on and your vehicle will honk when armed/disarmed.
If the chirps were on before you started, then you will hear 2 chirps indicating that they have been turned off.
Even if your alarm is run silently, if an intrusion is attemped your alarm will still indicate this with 4 chirps when the alarm is disarmed.
Panic Button:
On the transmitter, hold the lock button for 3 to 4 seconds. The horn will honk continuously until you press the lock button again to turn if off.
Replacing battery in transmitter key:
Remove the 2 small phillips head screws from the bottom of the transmitter.
Use a small screwdriver and carefully unsnap the top cover of the transmitter away from the bottom cover.
Remove the discharged battery, making note of the location of the + and - contacts and replace with a new 12 volt type GP 27A battery.
Replace cover and secure with the small phillips screws.
