Blown headgasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2003, 05:18 PM   #1 (permalink)
View pbook's Photo Gallery
Blown headgasket
I have a 98 Tacoma 4-cyl with what appears to be a blown HG. I had the thermostat replaced just over a year ago and figured that the current overheating was due to another bad thermostat. Apperantly not. I did not let the engin run too hot I thought.
Anyway the engin only has 82K mi on it. Does anyone out there have any insite on weather or not this is a common problem with this engine?
Was there a recall that I can take advantage of?
Thanks...
pb
pbook is offline
Old 07-21-2003, 05:33 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Here ya go...........just pick which truck you have and this will tell you if there has been any TSB's on a blown head gasket:
http://www.alldata.com/TSB/9860_mo.html
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 07-21-2003, 05:49 PM   #3 (permalink)
Thanks that actually answered another question I had...
pbook is offline
Old 07-21-2003, 06:04 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
No problem man.
JeremyH is offline
Old 08-21-2003, 10:18 PM   #5 (permalink)
View eroc13's Photo Gallery
Smile i lost water in my engine
i have a 84 with a 22re and the water just started to disappear. it wasnt leaking anywhere and was driving me crazy.i did a compression check and the last cylinder was a lot lower than the others and the porcelan on the plug was real white.The head gasket was alowing the coolant to burn off in the last cylinder!!I could see where it was leaking when i took off the head gasket.
84 toy truck 22re
eroc13 is offline
