hard warm start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2003, 12:23 PM   #1 (permalink)
View 98tacoma's Photo Gallery
hard warm start
After the motor has been running and then shut it off for about 5-10 mins and then turn it back over it is really hesitent. I have heard that this could be caused by a faulty injector that is stuck open and floods the cylinder. what are your guys opinions on the matter and has anyone else had this problem?
98tacoma is offline
Old 08-26-2003, 12:31 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Usually if you have an injector firing incorrectly...it will trigger the O2 sensor and will show a check engine light as a result. Has this happened?
If not.....you might want to pull the injectors and give them a good cleaning using some carb cleaner or something on the order.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 08-26-2003, 12:38 PM   #3 (permalink)
It sure has you sound like you are on to it.
The check engine light comes on and off at random times and usually around the same time the idle get really rough going up and down and up and down. I originally wrote that off as a problem with my K&N drop in filter. Someone told me it was the filters oil that was sticking to the sensor that measures the air flow (sorry dont know the name) right after the filter and to just use electronic cleaner to clean it off.
should i just go get a motorvac done? I'm near my 60k but I dont know that I want to spend $300 on that right now.
98tacoma is offline
Old 08-26-2003, 03:44 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
I think you are referring the the MAF (maximum air flow).
However, it is very easy to clean the injectors yourself. I do this about once a year on my jeep. Just get in there and remove the bolts that hold on the fuel rail (that all the injectors are attached to). Any excess gas in the rail might leak out...but no biggie. Pull out the injectors slowly...be careful...they have o-rings on them that need to stay in good condition. I usually spray off the injector tips with some carb cleaner until all the build-up is gone. Then I spray the part of the block that they fit into with some carb cleaner as well...until all the gunk is gone. Then, just before you reinstall the injectors....lube the o-rings. I use Vaseline. Just use a little. Reinstall everything and you are set.
Dont use that crap from a bottle....it doesnt work. -----> See
Good Luck!
JeremyH is offline
Old 08-26-2003, 04:00 PM   #5 (permalink)
Listen Fatboy....
JeremyH's Avatar
Hell....you coulde even get one of these:
http://www.affordable-efi.com/afi_cleaning.htm
JeremyH is offline
Old 09-03-2003, 11:28 AM   #6 (permalink)
Just to let all of you know it did in fact turn out to be the K&N drop in filter that was causing these issues. Soon as I returned it to stock the motor is completely normal with no hard warm starts, check engine light is off and hasnt came back on, and idles smoothly.
98tacoma is offline
Old 09-04-2003, 10:28 AM   #7 (permalink)
nevermind that, check engine light came back on, bummer, time to go to the stealership
98tacoma is offline
Old 09-07-2003, 01:00 PM   #8 (permalink)
View DallasPottinger's Photo Gallery
VERY sorry to learn that the K&N filter wasn't the problem.
Warm-weather warm-engine hard re-start is chronic in my 96 Tacoma; mechanics over the years I've had this problem have thrown everything at it and not solved it. No engine light, just the hard re-starts. Clean injectors, good compression, wires fine, everything apparently in order.
Please post if you learn anything.
Thanks,
Dallas
DallasPottinger is offline
Old 09-10-2003, 12:01 PM   #9 (permalink)
Thanks,
Dallas
Will do, I'm just going to wait for the 60k service which is about 3500 miles away. I have no money to fix this crap now so it's going to have to be toyota tough til then. 3500 should fly by in about a month and a half. I'll let ya know.
98tacoma is offline
Old 10-10-2003, 12:54 PM   #10 (permalink)
View burchard's Photo Gallery
Have you checked your coolant temp sensor ( the one that sends the temp info to the computer?. Whenever is not stating when is warm, disconect the temp sensor and try to turn on the car. if you get your car running, reconnect the temp sensor and if it stalls, ther you go. good luck
burchard is offline
Old 10-10-2003, 12:57 PM   #11 (permalink)
it's starting, its just that its hesitent but thanks for your advise, something else to check out
98tacoma is offline
Old 10-10-2003, 01:31 PM   #12 (permalink)
Please read this post and see if it is of any use to you , good luck:
http://www.handymanwire.com/ubbthrea...rue#Post101839
burchard is offline
Old 01-06-2004, 04:40 PM   #13 (permalink)
happy to report that it turns out it was my K&N filter causing my problem. soon as i put my stockie back in and then reset the ecu the light hasnt come back on and its been at least 3 months.
98tacoma is offline
Old 01-07-2004, 10:54 AM   #14 (permalink)
Pls, what is a K&N filter. Thanks
burchard is offline
Old 01-07-2004, 09:47 PM   #15 (permalink)
http://www.knfilters.com/
98tacoma is offline
