90' toyota 4cyl 5 speed shifter problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2003, 10:21 PM   #1 (permalink)
View justin1's Photo Gallery
my truck seems to be slipping out of gear, especially 3rd and 4th gear. 1st, 2nd, and 5th seem ok. what could cause this? it is a standard transmission, 5-speed. i noticed that the oil was overfilled, could this be related to the problem? i let some oil out and it still does it. it seems like the shifter just pops out of gear especially over bumpy terrain. when i keep my hand on the shifter and hold it in gear, it doesn't pop out. sometimes it makes a grinding noise when i try to put it back into gear after it slips out. could i need a new clutch? any suggestions or comments are welcome. thank you
justin1 is offline
Old 09-01-2003, 11:49 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Have you recently added a body lift or anything? Motor mount lift? It could be that your shifter is barely hitting part of the body and that is not allowing it to set into gear. You might pull the outer boot and check.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 09-02-2003, 01:49 PM   #3 (permalink)
the truck has not been lifted or anything. it has never been a problem, and i just noticed it recently. what would i look for if i pulled the boot?
justin1 is offline
Old 09-02-2003, 02:38 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
To see if anything is between the body and the shifter keeping it from traveling the full motion into gear.
JeremyH is offline
Old 09-04-2003, 10:16 PM   #5 (permalink)
everything looks normal and it is a completely stock truck, no modifications. i think it could be transmission realted.
justin1 is offline
