?? about wheels, please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2003, 02:33 PM   #1 (permalink)
View Bud35fb's Photo Gallery
Question ?? about wheels, please help
i have a 95 4runner 4X4 SR5 and want to get a set of rims for it and i was looking at these ones but i'm not sure if they'll fit
here's the link for the one's i want
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2433739969
95 4runner 4X4, SR5....aftermarket stereo, speakers, and subwoofer...new brush/grille guard with fog lights
Bud35fb is offline
Old 09-22-2003, 09:07 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
You will need to find out the dimensions of both sets of rims....current and the ones you want. If, for example, your current rims are 17" in diameter and these are 15", the new ones might not clear your brake calipers. Also, you need to know the lug pattern and count on your current rims. You also might try to get a set with close to the same backspacing as your current rims so that they dont rub parts of the suspension.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 09-22-2003, 09:17 PM   #3 (permalink)
i have factory 15X7 tires and i was wondering if anyone knew what the backspacing and bolt pattern is for the factory rims
Bud35fb is offline
Old 09-22-2003, 10:21 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
Pulling a tire and measuring them both will be the easiest. For backspacing....lay the tire face down (so that the inside of the tire and rim is pointing up). Using a flat edge that is resting on the upper lip of the rim (not touching the tire) measure the the back onf the mounting surface....that is backspacing. The more the backspacing the less your tires stick out.
As for the bolt pattern....count the number of bolt holes first, then measure the distance between the centers of two of the holes. You will get measurements such as 5x4.5" (read as 5 bolt holes..4.5" apart)
Hope this helps.
JeremyH is offline
Old 12-20-2003, 06:24 PM   #5 (permalink)
View toyota4x4-12's Photo Gallery
i just bought a 82 pickup , and when i took the wheels off there were about ten washers on each bolt spacing the wheels out because they were rubbing, i think on the tie rod ends. Are these just the wrong wheels or what, because i took the wheels off of my other toyota and they rubbed also.
toyota4x4-12 is offline
Old 12-20-2003, 07:49 PM   #6 (permalink)
Listen Fatboy....
JeremyH's Avatar
Sounds like you need wheels with less backspacing.
Either that, or the tires on the truck are too wide.
JeremyH is offline
