need help bad.....93 4x4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2003, 09:55 AM   #1 (permalink)
View a10hogplt's Photo Gallery
ok here goes guys. truck runs great till it rains out, or is extremely humid and has rained a little. then, the truck will not start. sometimes you can crank and crank and eventually it will fire, then run crappy for the first few miles, then clear up. this problem has slowly gotten worse, and i cant figure it out. its to the point where if the truck sits out over night in the rain it wont start till the rain stops and it dries out, then it runs perfect. i've recently changed the plugs, wires, cap and rotor. can anyone help figure this out?
a10hogplt is offline
Old 10-05-2003, 07:31 PM   #2 (permalink)
View WKOBE88822's Photo Gallery
check your wiring hareness that goes under the intake and over the injection rail could be shaffed bad so grounds out when wet
WKOBE88822 is offline
Old 10-05-2003, 07:39 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
when it's wet, take a can of a water-displacer, along the lines of WD-40 and spray sections of ignition wires, trying to start after each spray, when it starts, your problem should be limited to a small area to check
have a water hose nearby just incase whatever you spray starts a fire
Tercel GTS is offline
Old 10-05-2003, 07:44 PM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
ignition wires, or distributor cap
-Nick
Nick is offline
Old 10-05-2003, 07:51 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
did this problem exist before you changed the cap?
Old 10-06-2003, 03:58 PM   #6 (permalink)
no...i figured it out...was the coil...thanks guys.
